Questions on the Arduino Motor Shield R3 and External power
Hello,
Hope this is the correct place to post this.
I'm Using the Arduino Uno (well eventually the Mega2560) along with the Arduino Motor Shield R3 to power a Unipolar Stepper motor.
I'll be running the stepper motor as a Bipolar stepper hooked up to the MS with the corresponding B (+, -) & A (+, -), Vin and GND connections.
The Stepper is 200 steps/rev, 1/8° step angle, 5.4V, 1.5A.
It works well, but I would like to keep it powered seperately. I'm powering the Arduino with 9VDC (Power jack).
I tried looking up information on the Arduino motor shield, but just found specs and overview.
I have both center taps from the 2 coils on the stepper motor hooked together and connected to Vin on the blue screw terminal bar.
The info on the motor shield mentions a jumper on the back of the shield you can cut to supply external power.
Would this be a possible solution by cutting the jumper and powering the center taps from the 2 coils to an external source instead of hooking it up to the Vin on the blue screw terminal block?
**Update:
After a bit of searching, I found a few articles & posts on this.
I have my Arduino Mega 2560 powered by 9V (through the jack), using a dedicated 9V, 1A voltage regulator.
I cut the Vin jumper on the Arduino Motor shield r3 and powering the MS with 9V into the Vin screw terminal.
And powering the stepper motor on a dedicated 6V, 1.5A voltage regulator.
I'm writing down all current draw from every component (and adding them up) on my robot and components I may add in the future.
I was having some major current draw which ended up being the servo for the head tilt (up/down). Not sure what it's called...the servo 'buzz'?, where the servo is constantly trying to keep it's position (probably due to the weight of the head). I did get a higher torque servo (107oz.in), but it still buzzes. May have to install a counter weight on the other side...
Argh, lol...when I try and modify my post, it keeps jumping up to where I can't see what I'm typing :~
Anyways, I noticed this while the robot was moving. The servo (head tilt up/down) & the stepper motor (rotate left and right) where acting erratically. Some times the stepper motor wouldn't respond until I stopped or the servo for the tilt would be delayed.
Guessing that the servo constantly trying to keep it's position (buzzing) must draw some serious amps.
Think I may have gone a bit off topic for this post.. :blush:
*Sorry about that Nick, didn't mean to post this in the wrong forum :confused:
