The diagram calls for a 10K resistor. I have 3x 330R resistors. Can I chain link them, and will 990R work for short usage? It's only 10R off correct?
I'm fairly new to these diagrams, and was thrown off by the analog pin connection. Does the following make sense?
-connect 5V power pin to thermistor (assuming it doesn't matter which way to plug in a thermistor, same as resistors)
-connect thermistor to 10K resistor
-connect pin 11 to same side of 10K resistor that the thermistor is plugged to
-plug 10K resistor to ground
The more usual way of drawing a thermistor is to have a normal resistor but with a line with arrow going diagonally through the resistor.
A bit like Thermistor - Wikipedia although I would put an arrow on the end and not the flat.
The way you have draw in it looks like there should be three connections and there is only two.
The other way is to draw it like you have but to draw a connection between the middle connection (wiper) and one end.
You can think of the analog pin as a 'ground' and the current is going from the 5v through the resistance of the thermistor and to ground.
The 'real' ground is there to keep the pin low, the analog read pin does not actually work as a ground so you need a ground to sink the current.
The resistor is needed to stop all of the current going to the ground pin.
There's probably a better way to describe it but I hope that makes sense.
