Queued Interrupts
Hello,
I'm not sure how an Arduino Uno or Mega would react in following situation:
void setup(){
  cli(); // disable interrupts
  initPeriodicWDTInterrupt(); // Using the WDT as a peroidic timer with 32 ms
  set_sleep_mode(SLEEP_MODE_IDLE);
  sleep_enable();
  delay(40); // wait 40 ms - ensure that an interrupt has occured and is queued
  sei();
  sleep_mode();
void loop(){
  // nothing to do here
ISR (WDT_vect){
  // do stuff
How will the program be executed?
sei() -> jump into ISR -> go to sleep
or
sei() -> go to sleep -> jump into ISR
Thanks for your help,
Robin
Hello,
perhaps someone else got the same question.
After around one hour of searching I found this:
"Now, the AVR architecture guarantees that after interrupts are enabled, at least one instruction runs uninterrupted. In this case, this means that the sleep_cpu() function (which translates to a single sleep instruction) always runs."
Source (topic Sleeping): (...) — Interrupts, sleeping and race conditions on Arduino
and the sleep_mode() function is defined as:
#define sleep_mode() \
do {                 \
    sleep_enable();  \
    sleep_cpu();     \
    sleep_disable(); \
} while (0)
So I think the correct answer is the first one:
sei() -> jump into ISR -> sleep
But if you change sleep_mode() to sleep_cpu(), which is defined as:
#define sleep_cpu()                              \
do {                                             \
  __asm__ __volatile__ ( "sleep" "\n\t" :: );    \
} while(0)
#endif
the first answer is correct:
Am I correct?
Yes. But IIRC delay does not work with interrupts disabled so the program will hung.
Yes sure, you're right.
Thanks!
