Quick 3 phase question
I have been looking into 3phase setups and one thing I wonder is, is it possible to have the 3 lower mosfets on the same heat sink hence tying them electrically together (sine the heatsink is conductive)? I know all the 3 top mosfets can be on the same heat sink. But I wonder if that also applies to the 3 lower.
Thanks!
Well, you have PNP/NPN type transistors drawn instead of P-channel/N-channel MOSFETs.
But anyway, the answer could be yes, as long as you select parts that have the 'tab' on the correct pin; and if not, yes if you use mica insulator/nylon spacer to insulate the tab from the heat sink. See this as example, found thru a search at digikey. http://www.keyelco.com/pdfs/M55p103.pdf
Hi, All should be NPN I want to use irfp250n http://www.hestore.hu/files/irfp250n.pdf The metal heat sink back part is on the Drain. So I guess on the high side all 3 mosfets can be electrically connected and it won't be a problem. But I wonder if all 3 low side fets can be on one heatsink as well. So having 1 heatsink for the high side fets and 1 heatsink for the low side fets.
No you can't do that, the drain will be on the load not the supply. You have to use insulated washers.
Thanks all, I indeed see now.
At least the low side fets need to be all isolated. Thanks!
and the high side ones, if they are P-channel then it will be the source at the +ve supply. If they are N-channel then they will only work as a source follower and do you want that configuration?
