I would like to offer $5 usd to the first person that can add potentiometer adjustment to the code bellow. Payment will be made via paypal
Currently the code will move a servo horn 90° from a starting position of 5° when a button is pressed. It will also hold the position until the button is released.
What I need is a potentiometer to be able to adjust the value of 90° to a value between 10° - 180°
The code can be posted as a reply, so that anyone can use/see it.
If this is not possible or if I'm too cheap!, please feel free to let me know.
Thanks
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 5
; // variable to store the servo position
int button = 2; // The button will be on Pin 7
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(pos, OUTPUT);
pinMode(button, INPUT);
digitalWrite (button, LOW);
if (digitalRead(button) == LOW)
for(pos = 5; pos < 90; pos += 90) // goes from 0 degrees to 90 degrees
{ // in steps of degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
// waits 1s for the servo to reach the position
if (digitalRead(button) == HIGH)
for(pos = 90; pos>=90; pos-=90) // goes from 90 degrees to 0 degrees
delay(5); // waits 50ms for the servo to reach the position
Thanks
#include <Servo.h>
int pos = 5; // variable to store the servo position
int destination = map(analogRead(A0), 0,1023, 10, 180); // fixed typo
if (digitalRead(button) == LOW) { // Button pushed
myservo.write(destination);
else {
myservo.write(5);
I was looking for the pinMode for that.
Pins are Inputs by default, I know, but since there was a pinMode for button I was caught up looking for one for "pot" (nonesuch).
[quote author=Runaway Pancake link=topic=257411.msg1820191#msg1820191 date=1406474898]
When are there ever pinMode calls for analog pins?
[/quote]
When you want to use an analogPin as digital output...
[/quote]
Fair enough. Let's append that statement:
When are there ever pinMode calls for analog input pins?
Arrch: When are there ever pinMode calls for analog input pins?
I really didn't know that there weren't, that it's unnecessary, and I think that I made that clear.
After a couple of years, I didn't know that analogWrite doesn't require a pinMode call either.
The Reference doesn't note that pinMode calls for analog inputs (vis-a-vis analogRead) are unnecessary.
Technically, a digital input doesn't require a pinMode call either (but there's one up there - and I'm OK with it.)
So, like I said before, already, I went down the rabbit-hole!
Now, if you'll pardon me, I have to go set fire to myself in the backyard.
Thanks to everyone so far for their contribution, especially John.
I have tried to upload the code by John to an Arduino UNO board and I get the following errors;
\arduino-1.0.5-r2\hardware\arduino\cores\arduino/Arduino.h: In function 'void loop()':
\arduino-1.0.5-r2\hardware\arduino\cores\arduino/Arduino.h:101: error: too many arguments to function 'int analogRead(uint8_t)'
test:21: error: at this point in file
\arduino-1.0.5-r2\hardware\arduino\cores\arduino/Arduino.h:209: error: too few arguments to function 'long int map(long int, long int, long int, long int, long int)'
