Hi Guys,
I know the Arduino uses a modified version of C language, but I'm struggling here. I know there will hundreds that will fix this in seconds.
I found an LED strip reaction game that is coded for MakerBoard, but wish to use it with the Arduino. Seems quite simple code, but...No matter what I do it errors on LEDStrip is not a name. Could someone please change the following code to work for me please.
My LED Strip is on data pin 2.....button I can put anywhere. Already use NeoPixel library. Maybe FastLed is needed.
Many Thanks
- Reaction game- press the button when the moving pixel overlaps
- the center one. Speed increases each time you succeed
//Include the LEDStrip library to use the commands
#include "LEDStrip.h"
const byte numPixels = 15; //Number of pixels on a strip
const byte middlePixel = numPixels/2; //The pixel at the middle of your strip
int pixel = 0; //Position of the pixel on the strip
const int hitColor = 50; //The color of the strip when you hit the mark
const int missColor = 100; //The color of the strip when you miss the mark
int Direction = 1; //Direction of travel of the pixel
int delayTime = 300; //Starting time (in ms) between pixel movements
long timer = millis(); //Timer to control movement of pixel
- Make the LED strip object LEDStrip strip
- = LEDStrip(numPixels, dataPin (DI), clockPin (CI));
LEDStrip strip = LEDStrip(numPixels, 13, 12);
//Button
pinMode(A5,INPUT_PULLUP);
//If at the center pixel
if (pixel == middlePixel){
strip.setPixel(pixel,(hitColor+missColor)); //overlap the colors
//If the button is pressed while on the center pixel
if (digitalRead(A5) == LOW){
delayTime= delayTime*.75; //delayTime reduced by 25%
//Blink the hitColor to indicate success
strip.setPixel(strip.ALL,hitColor);
strip.draw();
strip.clear();
//When not on the center pixel
if (pixel != middlePixel){
strip.setPixel(pixel,missColor); //Set the moving pixel
strip.setPixel(middlePixel,hitColor); //Set the center pixel
//If button pressed when not at center
//Blink all pixels the missColor for a second
strip.setPixel(strip.ALL,missColor);
strip.draw();
strip.clear();
delayTime = delayTime + 100; //Slow down the ball
//Every delayTime many ms, update pixel position
if (millis()-timer > delayTime){
timer = millis(); //Reset the timer
strip.setPixel(pixel,-1); //Clear previous pixel
pixel = pixel + Direction; //Move the pixel
//If at either end of the strip, change direction of travel
if ((pixel == 0)||(pixel == numPixels-1)){
Direction = Direction*-1;
strip.draw(); //Draw what was written to the strip this loop
//Change the reduction to delayTime time to make the game move more
// quickly
