Quick doubt, mapping POT values to mouseX
http://pastebin.com/ZqMp6gdU Please look line 64,65
This is my processing sketch. Instead of mapping to mouse, i'd like to control the interaction with my potentiometer. :grin:
-What changes shall i make in this code? So that i rotate the POT and the interaction happens accordingly.
This sketch increases frequency of a tone as you mouse mouse to right side on the screen.
You need to do something "similar" to the way you read serial input on the Arduino. You've done the initialisation OK.
     while ( port.available() > 0) {
       inChar = port.read();         // read it and store it in val
       println(inChar) ;             // optional debugging
       if (inChar == 'd') {          // If the serial byte received is a "d"
         fill(50);                   // set fill to dark Gray
         rect( width/2, 0, width/2, height);
       if (inChar == 'u') {          // If the serial byte received is a "u"
         fill(200);                  // set fill to light Gray
     // Which implies that any other characters are simply ignored/discarded
This Processing code will colour a rectangle whenever the Arduino does a Serial.print('d') or Serial.print('u').
So in your Arduino loop you sample the POT and send a character (hint: Use Serial.write, not print) which the Processing port.read() receives as a binary number.
