Hi, everyone. I am really to Arduino. I'd like to quicklly ask about the fading out led.
The fading in is working now. And I would like my led fading out when button pressed. Really apprieciate any help!
Here is my code:
int led = 9;
int button = 2;
int brightness = 0;
int fadeAmount = 5;
pinMode(button, INPUT_PULLUP);
pinMode(led, OUTPUT);
analogWrite(led, brightness);
brightness = brightness + fadeAmount;
brightness = constrain(brightness, 0, 200); //constrain the maximum brightness
if (button == LOW){
brightness = brightness - fadeAmount;
delay(100);
int led = 9;
int button = 2;
int brightness = 0;
int fadeAmount = 5;
// read current state of button and make either a
if (digitalRead(button)) {
// decrement
else {
// or increment
// limit value
// write value
// and wait for next round
delay(100);
Дайте миру шанс!
The human eye sees brightness with a steep curve, close to a 10log curve. If the sketch would use such a steep curve, then the dimming will look more natural.
Follow the logic in your loop(). You increment the brightness with brightness = brightness + fadeAmount and if the button is pressed you decrement it with brightness = brightness - fadeAmount. The end result is that there is no change in the brightness when the button is pressed.
