Quick help with millis()
void activeTouch()
  unsigned long activeTime = millis(); //this is when the function was called
  while(true)
    if(digitalRead(button1))
      digitalWrite(led1, false);
      activeTime = millis(); //reset countdown if button is pressed
      digitalWrite(led1, true);
      if( millis() - activeTime > deactivateTime) //after "deactivateTime" milliseconds of no button pressing, exit
        return; //exit activeTouch() function
    Serial.println("active");
    delay(100); //add a little delay
While keeps looping...
Post your code.
Sorted now...Please check
const byte button1 = 30;
const byte button2 = 32;
const byte led1 = 22;
const byte led2 = 23;
const byte redPin = 12;
const byte greenPin = 11;
const byte bluePin = 10;
byte  hold = false;
unsigned long switchOn = 0;
boolean isButtonHeld = false;
const unsigned int holdTime = 3000;
const unsigned int deactivateTime = 3000;
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(redPin, HIGH);
  pinMode(greenPin, HIGH);
  pinMode(bluePin, HIGH);
   if(digitalRead(button1) == LOW)
    if(!isButtonHeld) //only activate once!
      switchOn = millis();
    isButtonHeld = true;
   Serial.print(millis());
   Serial.print(" deactivated: ");
   Serial.println(switchOn);
  if(isButtonHeld && millis() - switchOn > holdTime) //button has to be held AND for at least "holdTime" milliseconds
      activeTouch();
void activeTouch()
boolean beenPressed = false;
  while(!beenPressed)
    Serial.println(millis());
      digitalWrite(led1, HIGH);
      beenPressed = true;
      digitalWrite(led1, LOW);
      if(beenPressed == false && millis() - activeTime > deactivateTime) //after "deactivateTime" milliseconds of no button pressing, exit
Just have to put all in array as i have 13 inputs 8 outputs.... that is another challenge
Missing curly braces in active touch
Weird… it does exactly what i want.It keeps looping for 3 seconds, if i press in between those 3 seconds timer resets and countdown starts again.
Sorry Im so random replying, work and school kinda get in the way, sometimes Im just checking with my phone...
Here is a snippet from your code that has a problem
while(!beenPressed)
      beenPressed = true;
See that "else", there is no curly braces after that, so it is always doing "beenPressed = false;" which makes the next if statement a little pointless
if(beenPressed == false && ...
it is always false, why bother checking it...
Make it this
Although, Im looking and I am also noticing another issue. If you add those braces, this will happen.
  1. You press and hold the button
  2. It takes you to activeTouch()
  3. It sees you pressing the button and sets beenPressed to true, exiting the function
  4. loop still sees you pressing the button and doesnt reset the isButtonHeld flag, thus it takes you too activeTouch() again
  5. The loop repeats
Try this
byte  hold = false;
      activeTouch();
      isButtonHeld = false; //just a precaution to keep the program consistent until all circumstances
void activeTouch()
  while(true)
      if(millis() - activeTime > deactivateTime) //after "deactivateTime" milliseconds of no button pressing, exit
Ps991 Your code also work. Thank you.
