Quick LED Resistor question
Hi all,
Hopefully a quick question, I have this LED here:
http://www.ebay.com.au/itm/1xSuper-Bright-3Watt-LED-Lamp-with-Aluminium-Heatsink-BLUE-RED-AMBER-WHITE-GREEN-/271254082666?hash=item3f2800d46a:g:HQ8AAOxyFIFSAiqp
The relevant specs from the ad are:
Input: 2.5V - 3V
Colours: BLUE, RED, AMBER, GREEN, WHITE
Brightness: 70-80 Lemuns
Weight: 4g
I have the white one.
The power source I'll be running off is a 14.8 LIPO (voltage can get a bit higher than that when charged).
Can someone confirm what resistor I need, in particular the wattage needed to run this LED properly?
Is a resistor the best way to go about powering this?
No resistor, you need a constant current supply for something this big.
suspected that might be the case, thanks very much for the quick reply.
Cheers,
Matt
