quick noob question
i am starting a project where my arduino is a heater controller
i want a LCD to display current temp and desired temp
i then want to be able to adjust the desired temp with buttons
easy so far
but how do i save the setting into the arduino so if i loose power the setting is saved rather than having to adjust it on the sketch then upload again
thanks
steve :)
Check out EEPROM
http://www.arduino.cc/en/Reference/EEPROM
The EEPROM is where you store data that needs to be remembered even when the power gets turned off.
awesome
thank you :slight_smile:
