hi all, newbie to arduino here, anyway im working on a project involving a nano, 2 dc motors controlled with joysticks, and a servo controlled by push buttons. I have a L298n controlling the 2 dc motors. anyway the problem im having is with the coding, iv managed to get the coding for the motors to work in 1 sketch and the servo in another sketch i just cant seem to add them both together to make them all work off 1 nano. heres the code for the servo controlled by push buttons
#include<Servo.h>
int pos = 0;
Servo servo;
pinMode(2, INPUT);
pinMode(11, INPUT);
servo.attach(10);
if (digitalRead(2) == HIGH && pos < 180) {
pos++;
servo.write(pos);
delay(10);
if (digitalRead(11) == HIGH && pos > 0) {
pos--;
servo.write(pos);
delay(10);
and heres the code for the motors via L298n H bridge controlled with joysticks
// Motor A
int enA = 9;
int in1 = 8;
int in2 = 7;
// Motor B
int enB = 3;
int in3 = 5;
int in4 = 4;
// Joystick Input
int joyVert = A0; // Vertical
int joyHorz = A1; // Horizontal
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
int MotorSpeed2 = 0;
// Joystick Values - Start at 512 (middle position)
int joyposVert = 512;
int joyposHorz = 512;
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Start with motors disabled and direction forward
// Motor A
digitalWrite(enA, LOW);
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Motor B
digitalWrite(enB, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Read the Joystick X and Y positions
joyposVert = analogRead(joyVert);
joyposHorz = analogRead(joyHorz);
// Determine if this is a forward or backward motion
// Do this by reading the Verticle Value
// Apply results to MotorSpeed and to Direction
if (joyposVert < 460)
// This is Backward
// Set Motor A backward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
//Determine Motor Speeds
// As we are going backwards we need to reverse readings
joyposVert = joyposVert - 460; // This produces a negative number
joyposVert = joyposVert * -1; // Make the number positive
MotorSpeed1 = map(joyposVert, 0, 460, 0, 255);
else if (joyposVert > 564)
// This is Forward
// Set Motor A forward
MotorSpeed1 = map(joyposVert, 564, 1023, 0, 255);
// This is Stopped
MotorSpeed1 = 0;
if (joyposHorz < 460)
// This is Backward
// Set Motor B backward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
joyposHorz = joyposHorz - 460; // This produces a negative number
joyposHorz = joyposHorz * -1; // Make the number positive
MotorSpeed2 = map(joyposHorz, 0, 460, 0, 255);
else if (joyposHorz > 564)
// This is Forward
// Set Motor B forward
MotorSpeed2 = map(joyposHorz, 564, 1023, 0, 255);
// This is Stopped
MotorSpeed2 = 0;
// Adjust to prevent "buzzing" at very low speed
if (MotorSpeed1 < 8)MotorSpeed1 = 0;
if (MotorSpeed2 < 8)MotorSpeed2 = 0;
// Set the motor speeds
analogWrite(enA, MotorSpeed1);
analogWrite(enB, MotorSpeed2);
if anyone is able to help me merge these to sketches to work together it would be much appreciated.
