Quick question about current draw
Is there a way to detect whether or not a pin set as OUTPUT is actually being drawn from
Example.
Lets take a simple LED
case 1.
LED cathode = pin 8
LED anode = pin 9
case 2.
LED cathode = pin 9
LED anode = pin 8
in my setup i set pin 8 and 9 as OUTPUT
lets say that by default my program runs for anode on pin 9
digitalWrite(8, LOW);
digitalWrite(9, HIGH);
is there a way to test if current is actually being drawn from pin 9?
and if not, then reverse and set
digitalWrite(8, HIGH);
digitalWrite(9, LOW);
thanks in advance for tips, hints, tricks and such
You could measure the voltage across the current limiting resistor with an analogue input.
You could check the datasheet and see if an ADC pin can be used as a digital output
and an analog input. Depending on the current you may be able to measure the voltage drop across the output transistor. This would give you a few pins.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
the resistor idea sounds like it may work
will try it out
Yes it can. Just refer to A0 as pin 14, A1 as pin 15 and so on.
At the same time? If you could force the output to a high or low value and
then measure the voltage drop across the output transistor you would
know if current is flowing.
(* jcl *)
At the same time?
No the output stage is not built like that. You have to do some external stuff like a resistor or bridge rectifier.
