Quick question about fuse bits & bootloaders
I am trying to run a standalone atmega328p at 3.3v with the 8 MHz internal oscillator. Timing is not important in my application as it is handled by an RTC chip.
Is it as simple as uploading the 8MHz bootloader (using this tutorial: http://arduino.cc/en/Tutorial/ArduinoToBreadboard) and plugging in a 3.3v supply or do I need to mess with the fuses to get it to work?
Thanks
Is the processor brand new?
Will you be using a bootloader or ISP?
Processor is brand new. Will be using bootloader (burned with an ISP) then an onboard FTDI chip for serial comms/uploading firmware. Just need to figure out which bootloader to burn.
I did something very similar here:
Saved the day again Nick. I need to start checking your website before posting anything from now on!
Thanks a lot!
