Quick question about wall wart
Is there a maximum current rating that the Arduino can have as power? For example, can I run the arduino off a 2000mA 12v wall-wart?
Yes, the current rating on the wall wart is how much i CAN deliver max, Arduino will, only draw what it needs.
with 12v expect the regulator to get warm tho
Yes you can also run it off a 4 Amp one or a 30 Amp one or even a 0.3 amp one.
Your question indicates that you have a lot to learn about the difference between voltage and current, I would do some googling around that topic before you do much else to avoid disaster.
Yeah, mike's right, I'm a noob at that kind of stuff...
And MikMo, YOU can supply current? Wow! Free energy! Or do you need to plug yourself into an electrical socket?
;D
If you only draw a tiny current (50mA) off a 2A wall wart that is nominally 12V, you may find it is actually supplying 16V or some such because it is not regulated - they don't normally say on the label if they are regulated or not if a cheap wall wart. 16V may cook the arduino. Try measuring the output open-circuit to make sure.
