Quick question: Garland LED strip for ESP32?
Take a look at these led strips:
Garland LED strips
Is it possible to light up these with ESP32 and change colors etc.? I think about the RGB version.
How many LEDS?
What are the specs?
voltage? current needs?
Look under spesification on the product. All data is there. :slight_smile:
You'll need a transistor or MOSFET driver circuit and a power supply of the right voltage, capable of supplying the required current (Amps/milliamps). If you have 3 channels (3 separately controlled colors) you'll need 3 output pins and 3 drivers.
If you don't have the current specs you can estimate about 20mA for each regular LED or 60mA for an RGB LED.
