Quick Question: MQTT and SSL codabese port from ESP8266 to ESP32
Hey guys,
I'm working on migrating a codebase from the ESP8266 into the ESP32 for it's larger number of pins and more power. I believe I have mostly completed the whole migration except for the MQTT SSL area as I am not sure what is the equivalent code on the ESP32 and I was hoping you could shed some light.
static const char digicert[] PROGMEM = R"EOF(...CERTIFICATE HERE...)EOF"
//... A bunch of code
//Define WifiClientSecure/pubsubclient/set CA Cert list
WiFiClientSecure client;PubSubClient mqttclient(client);
X509List cert(digicert); //This here is the problem, X509List is not available in the ESP32
[code]Serial.println("Setting Trusted Anchors...");
 client.setTrustAnchors(&cert);
Serial.println("Trusted Anchors set! System will now check for CA.") ;
//NTP is required for CA Cert Validation
setClock();
You mean this thing do https://forum.arduino.cc/index.php?topic=695107.0? See the last few postings.
