Quick question on my wiring
Hi guys, I've changed my setup yet again, but just wanted to double check with you if my wiring is OK (really don't feel like frying something) as I'm new to this shield. Since a picture is worth a thousand words, heres a "drawing" of my setup.
The pins for the Pololu Dual Serial Low Voltage Controller are (left to right):
Pin 0 Motor supply
Pin 1 GND
Pin 2 Logic Supply
Pin 3 Serial In
Pin 4 Reset (according to the instructions any digital pin should work I'm assuming that I should connect it to the PWM pin not the 5V or GND)
Pins 5,6,7,8 Motors + and -
http://farm5.static.flickr.com/4011/4383036492_5a78fd7dfa_b.jpg
Sorry just found a problem with my link:
http://farm5.static.flickr.com/4011/4383036492_3104e052ac_b.jpg
