Quick question - what does this code do?
While going through the Adafruit ILI9341 library saw this line:
for(uint8_t bit = 0x80; bit; bit >>= 1){
I'm wondering, does it really means that every iteration of the 'for' loop contents of 'bit' variable is shifted right y one position?
And what is the end condition of this loop - 'bit' is left there by itself not equal to anything..
Thank you.
When you wrote a small test sketch which then printed 'bit' to the serial monitor, what was printed?
  Serial.println(bit);
The contents of a byte variable are ALWAYS equal to some value between and including 0 and 255.
Yes, that is indeed what happens if to run the code:
for (uint8_t bit = 0x80; bit; bit >>= 1) {
Serial.println(bit, BIN);
1 'traveled' to the right as the loop run.
10000000
01000000
00100000
00010000
00001000
00000100
00000010
00000001
(leading zeros were omitted in serial monitor)
But it still do not see why the loop stops once 1 reached the right side..
"bit" is an expression in C/C++ that returns the value of the variable bit.
When that value is zero, the loop terminates.
Sort of got it :smiley:
Thank you))
You could use these values to mask off bits in a variable to see if they are set or reset.
