system
December 2, 2013, 7:34pm
1
Hi, I need short and clear answer
This code is for example:
int pins[6]= {2,3,4,5,6,7};
int cols[3]= {pins[4],pins[5],pins[6]};
int rows[3]= {pins[1],pins[2],pins[3]};
If i want to acces pin 2 on arduino, do I have to write rows[0] or rows[1].
I don't know if I have to begin with 0 or 1 when using this things.
Robin2
December 2, 2013, 11:12pm
4
It would have been quicker to write a short sketch to try it out than to ask a question here - never mind waiting for the answer.
Where has personal initiative gone? Or the inquiring mind?
...R
MarkT
December 2, 2013, 11:45pm
5
ur000s:
pins[6]
is undefined, so the code is broken already. The pins array has
valid indexes from 0 to 5 inclusive.
Magicj
December 3, 2013, 12:59am
6
ur000s:
Assuming that the numbers {2,3,4,5,6,7} refer to the actual Arduino pins, then Pin 2 is referenced by
pins[0].
On the basis that you renumber you array indexes (from 1 -6 to 0-5) then rows[0] will be your answer.
Cheers
MarkT: The line:
is not broken. When an integer constant appears in brackets as part of a data definition, it defines the number of elements to be allocated in memory by the compiler...it is not an index into the array.
What about this line though?
