Quick question:
I'm not sure what this means:
stepperState = !stepperState;
does it mean stepperState is not equal to it's current state?
!= means not equal to, but not sure of =!
Thanks
It means reverse the state of stepperState. I.e. make stepperState equal to (not stepperState).
I hope stepperState is a boolean.
Steve
Thanks
paloian: does it mean stepperState is not equal to it's current state?
No, it means stepperState becomes equal to not its current state.
Assuming stepperState is a boolean, try:
stepperState ^= 1; // exclusive OR stepperState with 1 (flips it)
Test:
  static bool stepperState = false;
  stepperState ^= 1;
  Serial.println(stepperState);
From his description you can not assume StepperState is boolean. xor'ing the value with a 1 will only flip the low order bit. Any value can equate to a true and doing !value will change it to 0, if the value is not zero, and to 1 if the value is zero.
Don't use XOR for booleans, doing the !value will assure you of a boolean result even if the value is non-boolean. If you want to store 32 booleans in a int32 variable, then use XOR to flip individual bits, but that is a different question.
void IsItTrue(int value)
    if (value)
       Serial.print("value is non zero: ");
       Serial.print(value);
       Serial.print("\r\n");
       Serial.print("value is zero");
    int value = 99;
    IsItTrue(value);
    Serial.print("Not the value\r\n\r\n");
    value = !value;
    IsItTrue(value);
    value = !value;
    IsItTrue(value);
