quickfix code, pls help
hi, im trying to get this code working and its giving me an "unqualified id before “else” " error, and i’m not sure why, i tried fixing it and everything, but for now, ill keep fidgiting with it…
but if you can help me adn share your insights, that would be great!!
code:
int val = 0;
  backlightOn();
val = analogRead(0)/4.011764;
if (val > 252)
  selectLineOne();
  delay(50);
  Serial.print("It is very dark ");
  selectLineTwo();
  delay(50);
  Serial.print("in this room.");
  delay(100);
 else if (val > 246 && val < 252)
   selectLineOne();
   delay(50);
  Serial.print("It is pretty dark   ");
  selectLineTwo();
  delay(50);
  Serial.print("in this room.   ");
  delay(100);
 else if (val > 230 && val < 246)
   selectLineOne();
   delay(50);
  Serial.print("It is pretty   ");
  selectLineTwo();
  delay(50);
  Serial.print("bright here.   ");
  delay(100);
else if (val < 230)
  selectLineOne();
   delay(50);
  Serial.print("It is bright     ");
  selectLineTwo();
  delay(50);
  delay(100);
void selectLineOne(){  //puts the cursor at line 0 char 0.
   Serial.print(0xFE, BYTE);   //command flag
   Serial.print(128, BYTE);    //position
void selectLineTwo(){  //puts the cursor at line 0 char 0.
   Serial.print(192, BYTE);    //position
void clearLCD(){
   Serial.print(0x01, BYTE);   //clear command.
void backlightOn(){  //turns on the backlight
    Serial.print(0x7C, BYTE);   //command flag for backlight stuff
    Serial.print(157, BYTE);    //light level.
void backlightOff(){  //turns off the backlight
    Serial.print(128, BYTE);     //light level for off.
void serCommand(){   //a general function to call the command flag for issuing all other commands
thanks in advance to any help!
-int big93 = love you;
:slight_smile:
I don’t think there is anything wrong with your code. I expect the error is the arduino parser getting confused. The code below compiles ok and the only difference is a few spaces were added in the last else if statment.
int val = 0;
  backlightOn();
if (val > 252)
  selectLineOne();
  delay(50);
  selectLineTwo();
  delay(50);
  delay(100);
   selectLineOne();
   delay(50);
  selectLineTwo();
  delay(50);
  delay(100);
   selectLineOne();
   delay(50);
  selectLineTwo();
  delay(50);
  delay(100);
 else if (val < 230)
  selectLineOne();
   delay(50);
  selectLineTwo();
  delay(50);
  delay(100);
void clearLCD(){
Hi, the problem goes away when you move the loop() function right to the bottom of the sketch, so that all the methods called from loop() are above it. Might be a case of the way the arduino-ide creates prototypes for the functions automatically.
I had strange compiler messages like yours several times so I got into the habit of putting the loop()-function last in all my sketches.
Eberhard
Hi, just read the reply from "mem" and even a simple "Menu->Tools->Autoformat" make the error go away !?
Eberhard
thanks alot guys.... i got the code working strangly by simply removing the else commands, so they were all "if" commands insead of most of them being "else if".
this code works nicly, and i like it, it works well, ill post a vid later tonight when the sun has gone by by, and i can take a vid in my dining room where the light is dimmable....
