quickly (re)set an array
  int testar[4]={1,2,4,8};
  testar={0,0,0,0};
Is there a way to do something like this?
Or is there a way to quickly reset an array of ints? Or even better fill it with values, or do I need to put it in a for next loop or something?
This question must have been asked a thousand times before but I couldn't find an answer in the forum.
Use memset.
int testar[4] = {1, 2, 4, 8};
  int i;
  Serial.println("Testar ");
  for (i = 0; i < 4; i++) Serial.println(testar[i]);
  memset(testar, 0, sizeof(testar));
void loop() {}
Serial monitor:
Testar
1
2
4
8
Testar
0
0
0
0
interesting, thanks for the reply. Did not think of memset.
Does memset only write bytes or can I write ints as well with memset in Arduino?
It only writes bytes. Use:
memset(testar, 0, sizeof(testar)*sizeof(int));
You can use a for loop to set an array of any type to any value. It can even be done with no body for the for loop, if you are even a little bit clever.
