Quitter le sleep-mode avec une interruption TM1-OVF
J'arrive pas à quitter le sleep-mode avec une interruption logicielle (Timer1-overflow) personne à une idée ?? comment je peut le faire et merci par avance
Un code qui réveille le uc avec une interruption générée par Timer1 Overflow, ajuster le délai en fonction des besoins:
 * Sketch for testing sleep mode with wake up on timer.
 * Donal Morrissey - 2011.
#include <avr/sleep.h>
#include <avr/power.h>
#define LED_PIN (13)
volatile int f_timer=0;
 *  Name:        ISR(TIMER1_OVF_vect)
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Timer1 Overflow interrupt.
  /* set the flag. */
   if(f_timer == 0)
     f_timer = 1;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Enters the arduino into sleep mode.
void enterSleep(void)
  set_sleep_mode(SLEEP_MODE_IDLE);
  sleep_enable();
  /* Disable all of the unused peripherals. This will reduce power
   * consumption further and, more importantly, some of these
   * peripherals may generate interrupts that will wake our Arduino from
   * sleep!
  power_adc_disable();
  power_spi_disable();
  power_timer0_disable();
  power_timer2_disable();
  power_twi_disable();
  /* Now enter sleep mode. */
  sleep_mode();
  /* The program will continue from here after the timer timeout*/
  sleep_disable(); /* First thing to do is disable sleep. */
  /* Re-enable the peripherals. */
  power_all_enable();
 *  Name:        setup
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Setup for the serial comms and the
 *                timer.
  /* Don't forget to configure the pin! */
  pinMode(LED_PIN, OUTPUT);
  /*** Configure the timer.***/
  /* Normal timer operation.*/
  TCCR1A = 0x00;
  /* Clear the timer counter register.
   * You can pre-load this register with a value in order to
   * reduce the timeout period, say if you wanted to wake up
   * ever 4.0 seconds exactly.
  TCNT1=0x0000;
  /* Configure the prescaler for 1:1024, giving us a
   * timeout of 4.09 seconds.
  TCCR1B = 0x05;
  /* Enable the timer overlow interrupt. */
  TIMSK1=0x01;
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Main application loop.
  if(f_timer==1)
    f_timer = 0;
    /* Toggle the LED */
    digitalWrite(LED_PIN, !digitalRead(LED_PIN));
    /* Re-enter sleep mode. */
    enterSleep();
merci pour ce code. je le note dans un coin, ça va m'être utile sous peu :)
