R/C Arduino car question
Hey guys, I recently started learning Arduino and as I first project I decided to make an R/C car (so original I know haha). The thing is, everything was going well until I installed a buzzer. I wanted to make it play a song as a claxon but when I do that, the car won't make any other actions until the music stops.
I guess it is because Arduino can't handle 2 functions at once so I wanted to know if it possible to make the car read my inputs (forward, turn, etc) while the buzzer is sounding.
I can paste the code if needed.
Thanks a lot!
I think it would be better. My crystal ball is in the dish washer.
Post your sketch, well formated, with comments and in so called code tags "</>" to see how we can help.
Is the buzzer working in a simple test program?
Post that code and your attempt to integrate it with your successful r/c code.
a7
Sorry guys, I was at work, this the code
 * Carrito controlado mediante aplicacion movil echa en android studio
#include <SoftwareSerial.h>
#include <Servo.h>
#include "pitches.h"
SoftwareSerial miBT(2, 3);   //Instancia la conexion al bluetooth - PIN 2 a TX y PIN 3 a RX
int LED1B = 13;
int LED2B = 12;
int LED1R = 7;
int LED2R = 8;
int ZumbadorPin = 11;
// The melody array
int melody[] = {
  NOTE_FS5, NOTE_FS5, NOTE_D5, NOTE_B4, NOTE_B4, NOTE_E5,
  NOTE_E5, NOTE_E5, NOTE_GS5, NOTE_GS5, NOTE_A5, NOTE_B5,
  NOTE_A5, NOTE_A5, NOTE_A5, NOTE_E5, NOTE_D5, NOTE_FS5,
  NOTE_FS5, NOTE_FS5, NOTE_E5, NOTE_E5, NOTE_FS5, NOTE_E5
// The note duration, 8 = 8th note, 4 = quarter note, etc.
int durations[] = {
  8, 8, 8, 4, 4, 4,
  4, 5, 8, 8, 8, 8,
  8, 8, 8, 4, 4, 4,
  4, 5, 8, 8, 8, 8
// determine the length of the arrays to use in the loop iteration
int songLength = sizeof(melody)/sizeof(melody[0]);
//Entrada de los motores
int motor1A = 5; // INPUT 1
int motor1B = 6; // INPUT 2
int motor2A = 10; // INPUT 3
int motor2B = 9; // INPUT 4
int distance = 100;
      Servo servo_motor;
// Dato recibido atraves de la aplicacion movil
char data = 'S';
  pinMode(LED1B, OUTPUT);    // LED como salida
  pinMode(LED2B, OUTPUT);
  pinMode(LED1R, OUTPUT);
  pinMode(LED2R, OUTPUT);
  pinMode(ZumbadorPin, OUTPUT);
  //Definimos las salidas del motor
  pinMode(motor1A , OUTPUT);
  pinMode(motor1B , OUTPUT);
  pinMode(motor2A , OUTPUT);
  pinMode(motor2B , OUTPUT);
  Serial.begin(9600); //Inicia la comunicación en el monitor serial a 9600 Baudios
  miBT.begin(9600); // inicialmente la comunicacion serial a 9600 Baudios (velocidad de convencional)
  Serial.println("Módulo conectado");
    //Esperamos hasta que haya un Stream de datos
    if(miBT.available() > 0){
      data = miBT.read();
      Serial.println(data);
    switch (data) {
    case 'F':
      avanzar();        // Forward | AVANZAR
    case 'B':
      retroceder();     // Backward | RETROCEDER
    case 'L':
      izquierda();  //Left | IZQUIERDA
    case 'R':
      derecha();    //Right | DERECHA
    case 'S':
      detener();    //Stop | DETENER
    case 'G':
      giror();        // Forward left | AVANZAR IZQUIERDA
    case 'I':
      giroi();        // Forward right | AVANZAR DERECHA
    case 'H':
      giroatrasi();        // Backwards left | RETROCEDER IZQUIERDA
    case 'J':
      giroatrasr();        // Backwards rigt | RETROCEDER DERECHA
    case 'W':
    digitalWrite(LED1B, HIGH);
    digitalWrite(LED2B, HIGH);
     case 'w':
    digitalWrite(LED1B, LOW);
    digitalWrite(LED2B, LOW);
     case 'U':
    digitalWrite(LED1R, HIGH);
    digitalWrite(LED2R, HIGH);
     case 'u':
    digitalWrite(LED1R, LOW);
    digitalWrite(LED2R, LOW);
     case 'V':
     sonar();
      case 'v':
    delay(20);
void avanzar(){
  digitalWrite(motor1A, LOW);
  digitalWrite(motor1B, HIGH);
  digitalWrite(motor2A, LOW);
  digitalWrite(motor2B, LOW);
void retroceder(){
  digitalWrite(motor1A, HIGH);
  digitalWrite(motor1B, LOW);
void derecha(){
  //Right | DERECHA
  analogWrite(motor2A, 100);
void giror(){
  //Right | DERECHA
  analogWrite(motor2B, 100);
void izquierda(){
  //Left | IZQUIERDA
void giroi(){
  //Right | DERECHA
  digitalWrite(motor2A, HIGH);
void giroatrasi(){
  //Right | DERECHA
void giroatrasr(){
  //Right | DERECHA
void detener(){
  //Stop | DETENER
void sonar() {
  // Iterate through both arrays
  // Notice how the iteration variable thisNote is created in the parenthesis
  // The for loop stops when it is equal to the size of the melody array
  for (int thisNote = 0; thisNote < songLength; thisNote++){
    // determine the duration of the notes that the computer understands
    // divide 1000 by the value, so the first note lasts for 1000/8 milliseconds
    int duration = 1000/ durations[thisNote];
    tone(11, melody[thisNote], duration);
    // pause between notes
    int pause = duration * 1.3;
    delay(pause);
    // stop the tone
    noTone(11);
The thing is, in the app, once I press "W" it won't accept any other commands until I stop the W.
Some notations are in spanish because im spanish, if you don't understand something, just ask!
