I wrote this arduino code. It’s working fine but i just wanted to get your opinion about the code and can anything be done to improve the code.
The code is of a R/c car controlled by a analog joystick.
int val1 ; //variable to store pot value
int val2 ;
int val3 ;
int val4 ;
int val5 ;
int val6 ;
int val7 ;
int val8 ;
pinMode(5, OUTPUT) ;
pinMode(6, OUTPUT) ;
pinMode(10, OUTPUT) ;
pinMode(11, OUTPUT) ;
pinMode(13, OUTPUT) ;
int sensorValue1 = analogRead(A0);
delay(50) ;
int sensorValue2 = analogRead(A1);
delay(50) ;
int sensorValue3 = analogRead(A2);
delay(50) ;
int sensorValue4 = analogRead(A3);
if(sensorValue1 < 480)
val1 = map(sensorValue1, 0, 480, 0, 255) ;
val1 = 255 - val1 ;
analogWrite(5, val1) ; //pins of l293d ic
digitalWrite(6, LOW) ;
analogWrite(10, val1) ;
digitalWrite(11, LOW) ;
Serial.print("sensorValue1=");
Serial.println(val1, DEC);
analogWrite(9, val1) ;
else if(sensorValue1 > 510)
val2 = map(sensorValue1, 510, 1023, 0, 255) ;
analogWrite(6, val2) ;
digitalWrite(5, LOW) ;
analogWrite(11, val2) ;
digitalWrite(10, LOW) ;
Serial.print("sensorValue2=");
Serial.println(val2, DEC);
analogWrite(9, val2) ;
else if(sensorValue2 < 480)
val3 = map(sensorValue2, 0, 480, 0, 255) ;
val3 = 255 - val3 ;
analogWrite(5, val3) ;
analogWrite(11, val3) ;
Serial.print("sensorValue3=");
Serial.println(val3, DEC);
analogWrite(9, val3) ;
else if(sensorValue2 > 510)
val4 = map(sensorValue2, 510, 1023, 0, 255) ;
analogWrite(6, val4) ;
analogWrite(10, val4) ;
Serial.print("sensorValue4=");
Serial.println(val4, DEC);
analogWrite(9, val4) ;
else if(sensorValue3 < 480)
val5 = map(sensorValue3, 0, 480, 0, 255) ;
val5 = 255 - val5 ;
Serial.print("sensorValue5=");
Serial.println(val5, DEC);
analogWrite(9, val5) ;
else if(sensorValue3 > 510)
val6 = map(sensorValue3, 510, 1023, 0, 255) ;
Serial.print("sensorValue6=");
Serial.println(val6, DEC);
analogWrite(9, val6) ;
else if(sensorValue4 < 480)
val7 = map(sensorValue4, 0, 480, 0, 255) ;
val7 = 255 - val7 ;
Serial.print("sensorValue7=");
Serial.println(val7, DEC);
analogWrite(9, val7) ;
else if(sensorValue4 > 510)
val8 = map(sensorValue4, 510, 1023, 0, 255) ;
Serial.print("sensorValue8=");
Serial.println(val8, DEC);
analogWrite(9, val8) ;
analogWrite(6, LOW) ;
analogWrite(10, LOW) ;
Serial.print("sensorValue1==") ;
Serial.println(sensorValue1) ;
Serial.print("sensorValue2==") ;
Serial.println(sensorValue2) ;
Serial.print("sensorValue3==") ;
Serial.println(sensorValue3) ;
Serial.print("sensorValue4==") ;
Serial.println(sensorValue4) ;
Serial.println("No Action");
digitalWrite(9, HIGH) ;
delay(500) ;
