R301T fingerprint sensor
Hi guys!
Yesterday I received this sensor but all my attempts make it work were unsuccessful.
I found datasheet about this module here: https://www.openhacks.com/uploadsproductos/r301t_fingerprint_module_user_manual.pdf
And found the article here: https://wikidiys.com/fingerprint-using-arduino/
Also, I tried to use TTL level converter for TX and RX ports, but unfortunately without a result.
Function Adafruit_Fingerprint::verifyPassword() always return false.
The documentation says that this module has LEDs, but it does not glow when I power it.
And I don't know it should be glow?
I will be very appreciated for help.
Why? The UNO uses 5V levels as the fingerprint sensor does.
Post a wiring diagram of your setup (may be hand-drawn)!
Post the code you used so far (don't forget the code tags)!
