R307 sensor comparison algorithm
I would like to reproduce the fingerprint comparison algorithm so that the comparison is done outside the sensors. is there a way to achieve this?(with the SENSOR R305 OR R307 )
What is the comparison algorithm?
for a fingerprint reader like the R307 after having recorded the fingerprint then for verification the sensor has a comparison algorithm which checks the compatibility between the fingerprint placed and the one it has in its memory to determine if the fingerprint is recognized or not
Yes, that was clear. If you want to reproduce that algorithm, you have to know what the algorithm is.
You will probably also have to know exactly how the fingerprint data are stored and can be interpreted.
What have you learned so far from your research on the topic?
with my research I managed to find a way to have a template in hexadecimal format but for the same fingerprint the hexadecimal string will never be the same that is why the manufacturers of the fingerprint sensor insert an algorithm which analyzes the fingerprints and evaluates the confidence rate
Correct. Your next task is to find out what that algorithm is, so that you can reproduce it.
Come back to this thread when you have some actually useful information about that algorithm.
I'm looking for this, that's why I created this topic, I'm looking for leads and advice
Consider editing the title of your post to make your question clearer, and posting a link to the device. Such as "What is the fingerprint comparison algorithm in this reader?"
hope this is useful
