Brand new Arduino R4 Wifi.
I am using IDE 2.3.2
I have installed the board. I have it selected and the port.
I have a bare minimum script, and get this error:
Sketch uses 51504 bytes (19%) of program storage space. Maximum is 262144 bytes.
Global variables use 6744 bytes (20%) of dynamic memory, leaving 26024 bytes for local variables. Maximum is 32768 bytes.
No device found on cu.usbmodemF412FA63FC682
Failed uploading: uploading error: exit status 1
I am not able to upgrade the firmware. I am also not able to reset the arduino. PRessing the reset button does not cause the L Led to flash.
I have also followed the directions on here: https://support.arduino.cc/hc/en-us/articles/9670986058780-Update-the-connectivity-module-firmware-on-UNO-R4-WiFi
Any ideas?
Here is the verbose version:
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5
Using core 'arduino' from platform in folder: /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5
Detecting libraries used...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch/sketch_feb25a.ino.cpp -o /dev/null
Generating function prototypes...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch/sketch_feb25a.ino.cpp -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/4077733902/sketch_merged.cpp
/Users/zsozso/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/4077733902/sketch_merged.cpp
Compiling sketch...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2 > Zsozso Dén: 017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch/sketch_feb25a.ino.cpp -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch/sketch_feb25a.ino.cpp.o
Compiling libraries...
Compiling core...
Using previously compiled file: /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/common_data.c.o
Using previously compiled file: /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/pin_data.c.o
Using previously compiled file: /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/variant.cpp.o
Using previously compiled file: /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/main.c.o
Using precompiled core: /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/cores/arduino_renesas_uno_unor4wifi_140145762e905c130b1032c40838cef5/core.a
Linking everything together...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.elf -L/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF -L/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -T/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/fsp.ld /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch/sketch_feb25a.ino.cpp.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/common_data.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/main.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/tmp_gen_c_files/pin_data.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/core/variant.cpp.o -Wl,--whole-archive -Wl,--start-group /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/libs/libfsp. > Zsozso Dén: a /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/../../cores/arduino_renesas_uno_unor4wifi_140145762e905c130b1032c40838cef5/core.a -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group -Wl,-Map,/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/[sketch_feb25a.ino.map](https://web.telegram.org/a/sketch_feb25a.ino.map)
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary -j .text -j .data /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.elf /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.bin
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -j .text -j .data /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.elf /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.hex
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.elf
"/Users/zsozso/Library/Arduino15/packages/arduino/tools/bossac/1.9.1-arduino5/bossac" -d --port=cu.usbmodemF412FA63FC682 -U -e -w "/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/12B9184DC840AEDC889E24B1423CB5DF/sketch_feb25a.ino.bin" -R
This error might be caused by not having the port of the UNO R4 WiFi board selected from the Tools > Port menu in Arduino IDE.
Please perform this experiment to verify that the port you have selected is your Arduino board:
Connect the Arduino board to your computer with a USB cable (if it is not already).
Select Tools > Port from the Arduino IDE menus.
If one of the ports in the menu is labeled with the board name (e.g., "COM42 (Arduino Uno) "), that is the port of your Arduino board.
Select that port from the menu and try uploading again.
If the upload still fails, or if none of the ports in the menu are labeled with the name of your board, add a reply here to let us know and we'll investigate the problem further.
I have tried that.
When I click Tool, Port, I have selected cu.usbmodemF412FA63FC682 (Arduino R4 Wifi)
this is the output :
Zsozso Dén: FQBN: arduino:renesas_uno:unor4wifi
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch/sketch_feb26a.ino.cpp -o /dev/null
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch/sketch_feb26a.ino.cpp -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/1005300260/sketch_merged.cpp
/Users/zsozso/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/1005300260/sketch_merged.cpp
Compiling sketch...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2 > Zsozso Dén: 017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch/sketch_feb26a.ino.cpp -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch/sketch_feb26a.ino.cpp.o
Compiling core...
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 "-DPROJECT_NAME=\"/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/variant.cpp -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/variant.cpp.o
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defin > Zsozso Dén: es.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/main.c.o /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/tmp_gen_c_files/main.c
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/pin_data.c.o /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/tmp_gen_c_files/pin_data.c
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -c -w -Os -g3 -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu11 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10607 -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/tinyusb -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/api/deprecated-avr-comp -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino -I/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -iprefix/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5 @/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/includes.txt -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/common_data.c.o /Users/zsozso/Libr > Zsozso Dén: ary/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/tmp_gen_c_files/common_data.c
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -Wl,--gc-sections --specs=nosys.specs -w -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.elf -L/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066 -L/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4 -T/Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/fsp.ld /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch/sketch_feb26a.ino.cpp.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/common_data.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/main.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/tmp_gen_c_files/pin_data.c.o /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/core/variant.cpp.o -Wl,--whole-archive -Wl,--start-group /Users/zsozso/Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/variants/UNOWIFIR4/libs/libfsp.a /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/../../cores/arduino_renesas_uno_unor4wifi_140145762e905c130b1032c40838cef5/core.a -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group -Wl,-Map,/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/[sketch_feb26a.ino.map](https://web.telegram.org/a/sketch_feb26a.ino.map)
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary -j .text -j .data /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.elf /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.bin
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -j .text -j .data /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.elf /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.hex
/Users/zsozso/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.elf
Performing 1200-bps touch reset on serial port /dev/cu.usbmodemF412FA63FC682
"/Users/zsozso/Library/Arduino15/packages/arduino/tools/bossac/1.9.1-arduino5/bossac" -d --port=cu.usbmodemF412FA63FC682 -U -e -w "/private/var/folders/27/z7dft2gn10j44zyz2jb5lh8m0000gn/T/arduino/sketches/83BAA9A97732258C7F437579B4DA0066/sketch_feb26a.ino.bin" -R
Set binary mode
Send auto-baud
Set binary mode
system
Closed
August 24, 2024, 7:00pm
5
