R8875 adafruit lib
I am using adafruit R8875 lib for the same chipset with adafruit_glx graphic lib.These 2 libs use robot_control lib. My problem is that i get a compile error from the last lib.
The error is this and it is the same even if i try to compile an example from the arduino robot library
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp: In constructor ‘RobotControl::RobotControl()’:
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:8: error: ‘LCD_CS’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:8: error: ‘DC_LCD’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:8: error: ‘RST_LCD’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp: In member function ‘void RobotControl::begin()’:
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:18: error: ‘MUXA’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:18: error: ‘MUXB’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:18: error: ‘MUXC’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:18: error: ‘MUXD’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:19: error: ‘MUX_IN’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:22: error: ‘BUZZ’ was not declared in this scope
C:\Program Files\arduino\libraries\Robot_Control\ArduinoRobot.cpp:25: error: ‘Serial1’ was not declared in this scope
Any solution?
