Hello, I want to use the JPEGDecoder library with the Adafruit RA8875 Library. There are a few things in the jpeg decoding function that are not in the RA8875 Library. I don't know if there is an equivalent for the same function in the RA8875 Library. Here are the lines that are not found in the RA8875 Library:
tft.setAddrWindow();
tft.pushColor();
Does anyone know an equivalent for these two functions in the RA8875 Library? Here is the whole program:
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include "Adafruit_RA8875.h"
#include "Adafruit_SPIDevice.h"
#include "Adafruit_GFX.h"
#include "JPEGDecoder.h"
#include "SD.h"
#define RA8875_CS 5
#define RA8875_RESET 4
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
#define minimum(a,b) (((a) < (b)) ? (a) : (b))
void renderJPEG(int xpos, int ypos)
// retrieve infomration about the image
uint16_t *pImg;
uint16_t mcu_w = JpegDec.MCUWidth;
uint16_t mcu_h = JpegDec.MCUHeight;
uint32_t max_x = JpegDec.width;
uint32_t max_y = JpegDec.height;
// Jpeg images are draw as a set of image block (tiles) called Minimum Coding Units (MCUs)
// Typically these MCUs are 16x16 pixel blocks
// Determine the width and height of the right and bottom edge image blocks
uint32_t min_w = minimum(mcu_w, max_x % mcu_w);
uint32_t min_h = minimum(mcu_h, max_y % mcu_h);
// save the current image block size
uint32_t win_w = mcu_w;
uint32_t win_h = mcu_h;
// record the current time so we can measure how long it takes to draw an image
uint32_t drawTime = millis();
// save the coordinate of the right and bottom edges to assist image cropping
// to the screen size
max_x += xpos;
max_y += ypos;
// read each MCU block until there are no more
while ( JpegDec.read()) {
// save a pointer to the image block
pImg = JpegDec.pImage;
// calculate where the image block should be drawn on the screen
int mcu_x = JpegDec.MCUx * mcu_w + xpos;
int mcu_y = JpegDec.MCUy * mcu_h + ypos;
// check if the image block size needs to be changed for the right and bottom edges
if (mcu_x + mcu_w <= max_x) win_w = mcu_w;
else win_w = min_w;
if (mcu_y + mcu_h <= max_y) win_h = mcu_h;
else win_h = min_h;
// calculate how many pixels must be drawn
uint32_t mcu_pixels = win_w * win_h;
// draw image block if it will fit on the screen
if( ( mcu_x + win_w) <= tft.width() && ( mcu_y + win_h) <= tft.height())
// open a window onto the screen to paint the pixels into
//tft.setAddrWindow(mcu_x, mcu_y, mcu_x + win_w - 1, mcu_y + win_h - 1);
// push all the image block pixels to the screen
while (mcu_pixels--) tft.pushColor(*pImg++); // Send to TFT 16 bits at a time
// stop drawing blocks if the bottom of the screen has been reached
// the abort function will close the file
else if ( ( mcu_y + win_h) >= tft.height()) JpegDec.abort();
// calculate how long it took to draw the image
drawTime = millis() - drawTime; // Calculate the time it took
// print the results to the serial port
Serial.print ("Total render time was : "); Serial.print(drawTime); Serial.println(" ms");
Serial.println("=====================================");
tft.begin(RA8875_800x480);
tft.displayOn(true);
tft.GPIOX(true);
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024);
tft.PWM1out(255);
tft.setRotation(1);
if(SD.exists("arduino.jpg"))
Serial.println("arduino.jpg found on SD card.");
Serial.println("arduino.jpg not found on SD card.");
while (1);
Thanks.
