RA8875 not responding to this code
Hi Community,
Can anyone please help me understand why the following code doesn't work with my 7" TFT RA8875 Capactive TFT touch Screen and I already uncommented RA8875UserSettings.h file and uncomment USE_FT5206_TOUCH. I am using Mega 2560 Arduino.
Serial.begin(38400);
long unsigned debug_start = millis ();
while (!Serial && ((millis () - debug_start) <= 5000)) ;
tft.begin(RA8875_800x480);
#if defined(USE_FT5206_TOUCH)
tft.useCapINT(RA8875_INT);//we use the capacitive chip Interrupt out!
//the following set the max touches (max 5)
//it can be placed inside loop but BEFORE touched()
//to limit dinamically the touches (for example to 1)
tft.setTouchLimit(MAXTOUCHLIMIT);
//tft.setRotation(0);//this works in any rotation mode!
tft.enableCapISR(true);//capacitive touch screen interrupt it's armed
#else
tft.print("you should open RA8875UserSettings.h file and uncomment USE_FT5206_TOUCH!");
#endif
tft.setTextColor(RA8875_WHITE,RA8875_BLACK);
void loop(){
if (tft.touched()){//if touched(true) detach isr
//at this point we need to fill the FT5206 registers...
tft.updateTS();//now we have the data inside library
tft.setCursor(CENTER,CENTER);
tft.print(" ");
tft.print("touches:");
tft.print(tft.getTouches());
tft.print(" | gesture:");
tft.print(tft.getGesture(),HEX);
tft.print(" | state:");
tft.print(tft.getTouchState(),HEX);
//you need to get the coordinates? We need a bidimensional array
uint16_t coordinates[MAXTOUCHLIMIT][2];//to hold coordinates
tft.getTScoordinates(coordinates);//done
//now coordinates has the x,y of all touches
//now draw something....
uint16_t tempCol;
for (uint8_t i=1;i<=tft.getTouches();i++){
if (i == 1)tempCol = RA8875_RED;
if (i == 2)tempCol = RA8875_GREEN;
if (i == 3)tempCol = RA8875_MAGENTA;
if (i == 4)tempCol = RA8875_CYAN;
if (i == 5)tempCol = RA8875_YELLOW;
tft.fillCircle(coordinates[i-1][0],coordinates[i-1][1],10,tempCol);
tft.enableCapISR();//rearm ISR if needed (touched(true))
//otherwise it doesn't do nothing...
#endif
Appreciate your time and help.
