Hey guys, I backed a kickstarter which got me a couple Rabid Prototypes TAU boards. They are Arduino Zero compatible, so much so that if I have the TAU set in the boards manager and get board info, it reports as a Zero.
The problem I am having is I am trying to do a FastLED project with it, and it wont compile for the TAU. If I switch the board manager to Zero, it compiles.
The error I get is this.
fastpin.h:206:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), "Invalid pin specified");
I tried every pin and I get the same error.
From what I have googled, this means there is no board definition for the tau in FastLED.
I found this thread
opened 07:40PM - 18 May 16 UTC
closed 07:43PM - 18 May 16 UTC
I've got a strip of W8212 LED's hooked up to a custom PCB running a Atmega6… 44PA at 16Mhz, I'm using FastLED 3.1 and IDE 1.6.7. I get a compiling error whenever i include the FastLED library. I have the the DATA PIN connected to the PB7 pin on the 644 which translates to pin 15 in IDE. I've used this library before on a custom PCB running a Atmega328 at 16Mhz without any issue, i do see that with the Atmega328 PB7 would just be pin 7 in IDE and with the 644 it translates a bit differently (PB7 = pin 15)... So i don't know if that has something to do with it.
In file included from C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:40:0,
from C:\Users\feste\AppData\Local\Temp\arduino_ee0154f342bd35375a3767f897a1a60c\Blink.ino:1:
C:\Program Files (x86)\Arduino\libraries\FastLED-master/fastpin.h: In instantiation of 'class FastPin<4u>':
C:\Program Files (x86)\Arduino\libraries\FastLED-master/platforms/avr/clockless_trinket.h:96:49: required from 'class ClocklessController<4u, 4, 10, 6, (EOrder)10u, 0, false, 10>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/chipsets.h:322:7: required from 'class WS2812Controller800Khz<4u, (EOrder)10u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:92:52: required from 'class WS2812B<4u, (EOrder)10u>'
C:\Program Files (x86)\Arduino\libraries\FastLED-master/FastLED.h:263:39: required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812B; unsigned char DATA_PIN = 4u; EOrder RGB_ORDER = (EOrder)10u]'
C:\Users\feste\AppData\Local\Temp\arduino_ee0154f342bd35375a3767f897a1a60c\Blink.ino:22:62: required from here
C:\Program Files (x86)\Arduino\libraries\FastLED-master/fastpin.h:206:2: error: static assertion failed: Invalid pin specified
exit status 1
Error compiling.
TIA
(yes thats me at the end) that says you just need to
add a section defining the pin/port mappings for your board
I assume that has to do with adding a section like so
#elif defined(AVR_ATmega1284P )
I guess my main question is, how do I find out what processor definition the TAU is?
Can I just copy the one from the zero and make it work for the tau?
Where is the file that defines the zero?
Thanks!
westfw
August 18, 2017, 12:21am
2
Turn on the verbose option for compilation in the Arduino preferences, then copy the compile dialog and see what it defines.
For example, compiling for a genuine zero produces:
/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++
-mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections
-fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500
-fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L
-DARDUINO=10802 -D[color=red]ARDUINO_SAMD_ZERO[/color] -DARDUINO_ARCH_SAMD -D__SAMD21G18A__
-DUSB_VID=0x2341 -DUSB_PID=0x804d -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"'
'-DUSB_PRODUCT="Arduino Zero"'
"-I/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/"
"-I/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/tools/CMSIS-Atmel/1.1.0/CMSIS/Device/ATMEL/"
"-I/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/hardware/samd/1.6.15/cores/arduino"
"-I/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/hardware/samd/1.6.15/variants/arduino_zero"
"/Applications/arduino/Arduino-1.8.2.app/Contents/Java/portable/packages/arduino/hardware/samd/1.6.15/cores/arduino/WMath.cpp"
-o "/var/folders/jz/5yb8f2hr8xjcpf0059bsfz4r0000gn/T/arduino_build_637127/core/WMath.cpp.o"
Where the part I've highlighted is what fastpin_arm_d21.h uses to define some pins.
Probably, if they are as compatible as you say... Or change the #if statement to include several symbols
#if defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_TAU)
For those of you that may go looking for this info,
it appears to be..
ARDUINO_SAMD_TAU
