Racing Datalogger
Hello, first I will introduce myself . My name is malaltet I am from here and there and I do drift to amateur mode.
Now important, I am a lover of DIY and I consider making a dataLogger to monitor certain parameters of the car. The problem is that GPS does not seem to work, I suppose it's because it does not validate if (SERIAL_GPS.available ()> 0) or if (gps.encode (SERIAL_GPS.read))
That's the bad part, now the worst part, I thought that the GPS being Chinese would not work well or it should always be at open place, right ?. So I decided to try out an example of the GPS library and voila! In less than 10 seconds it picks up the GPS signal. I have been trying to solve the problem for about a month and I do not know what it can be ... I am desperate to see that the same code works in one and not in another ... hahaha
(accept improvements and correction of errors)
// Libraries
#include <TinyGPS++.h>
#include <SD.h>
#include <Wire.h>
#include <LCD.h>
#include <LcdBarGraphX.h>
#include <SoftwareSerial.h>
//Cambiamos de nombre Serial a SERIAL_GPS
static const int RXPin = 4, TXPin = 9;
SoftwareSerial SERIAL_GPS(RXPin, TXPin);
//Digital Pins
#define LED_STATUS_PIN 7 // LED pin to show current status, helpful for debugging.
#define LED_GPS 6 //LED para saber si el GPS recibe datos
#define BRAKE_PIN 5 //Aun no he encontrado ningun sensor de freno...
#define STOP_SWITCH_PIN 8 // Pushbutton switch to stop program
//Pins SD
#define SD_PIN 10 // SD SS Pin
#define MOSI_PIN 11 // SD MOSI Pin
#define MISO_PIN 12 // SD MISO Pin
#define SCK_PIN 13 // SD SCK Pin
// Analog Pins
#define TPS_PIN A0 // Throttle Position Sensor
#define AIR_TEMP_PIN A1 //Sensor de temperatura de la entreada de aire
#define ENG_TEMP_PIN A2 //Sensor de temperatura del motor
// Initialize TinyGPS Variables
TinyGPSPlus gps;
// Initialize SD File Variable
File dataFile;
// Initialize Global Variables
int  tpsValue, airTemp, engTemp;  //Si brake value es un numero entre 1 y 0 se cambiara la variable para que ocupe menos espacio
byte brakeValue;
//Inicio del LCD
#define I2C_ADDR    0x27
LiquidCrystal_I2C             lcd( I2C_ADDR, 2, 1, 0, 4, 5, 6, 7);
LcdBarGraphX lbg(&lcd, 8, 1, 0);    //lbg(lcd, longitud del grafico, columna inicio, fila);
LcdBarGraphX lbg1(&lcd, 8, 1, 1);
LcdBarGraphX lbg2(&lcd, 6, 9, 0);
LcdBarGraphX lbg3(&lcd, 6, 9, 1);
  SERIAL_GPS.begin(9600);
  setIoPins(); // Initialize IO Pins
  setLCD(); //Inicia el LCD
  setSerial(); // Initialize Serial ports
  setSdCard(); // Initialize SD Card
  createFile(); // Create File
  lcd.clear();
  checkStopSwitchPin();
  if (SERIAL_GPS.available()) {   // If TinyGPS detects parsable data from serial port
    int c = SERIAL_GPS.read();
    if (gps.encode(c)) {
      getSensorData(); // Then get sensor data
      writeToSdCard(); // Write data to SD Card
    do
      displayInfo();
      } while (gps.encode(c));
void setIoPins() {
  // Intitialize input pins
  pinMode(BRAKE_PIN, INPUT);
  pinMode(TPS_PIN, INPUT);
  pinMode(STOP_SWITCH_PIN, INPUT_PULLUP); // SD Switch set to normally HIGH, will go to LOW when pressed
  // Initialize output pins
  pinMode(LED_STATUS_PIN, OUTPUT);
  pinMode(LED_GPS, OUTPUT);
  pinMode(SD_PIN, OUTPUT);
  // Initialize HIGH pins
  digitalWrite(LED_STATUS_PIN, HIGH);
  digitalWrite(LED_GPS, LOW);
void setSerial() {
void setSdCard() {
  if (!SD.begin(SD_PIN)) { // If SD SS Pin is false for whatever reason then
    lcd.clear();
    lcd.print(F("Fallo en SD"));
    flashLed(1); // Flash loop LED once and halt
  lcd.clear();
  lcd.print(F("SD Iniciada"));
  delay(1500);
// After SD Card has been initialized, file will be created once GPS has a lock.
// This is done by setting isFileCreated boolean to true and will finally cause
// program to leave while loop.
// TODO: Reduce control flow inception (ie. too many loops within loops) for sanity purposes.
void createFile() {
  boolean isFileCreated = false;
  while (!isFileCreated) {
    if (SERIAL_GPS.available() > 0) {
      // Create a new file using character array.
      // Must use '0' because if int i = 1 then i/10 = 0.1
      // but since its an integer, i/10 = 0 due to rounding cutoff
      // and 0 + 0 = 'null' character
      // but 0 + '0' = 0 + 48 = '0' character
      // Reference ASCII chart for dec to char value
      char filename[] = "LOGGER00.CSV"; //Crea un array de 12 elementos, uno por cada letra del nombre del archivo
      for (byte i = 0; i < 100; i++) {
        filename[6] = i / 10 + '0'; //Incrementa el valor para crear archivos nuevos
        filename[7] = i % 10 + '0';
        if (!SD.exists(filename)) {
          // only create a new file if it doesn't exist
          dataFile = SD.open(filename, FILE_WRITE);
          //SERIAL_DEBUG.print(F("File "));
         // SERIAL_DEBUG.print(filename);
          //SERIAL_DEBUG.println(F(" has been created."));
          isFileCreated = true;
          lcd.clear();
          lcd.print(F("     CREADO     "));
          lcd.setCursor(1,1);
          lcd.print(filename);
          delay(3000);
          break;  // leave the for loop! This is done so only one file is created
          // which is the first number that does not exist yet
  if (!dataFile) { //En el caso de que no se haya podido crear el archivo...
    //SERIAL_DEBUG.println("could not create file.");
    lcd.clear();
    lcd.print(F(" Fallo al crear "));
    lcd.setCursor(0, 1);
    lcd.print(F("   el archivo   "));
    flashLed(2); // Flash loop led twice and halt
  String header = (F("LAT;LON;l.AGE;DATE;TIME;ALTITUDE;KM/H;TPS;BRAKE"));
  dataFile.println(header);
void checkStopSwitchPin() {
  if (digitalRead(STOP_SWITCH_PIN) == LOW) {
    lcd.clear();
    lcd.print(F("Cerrando..."));
    dataFile.close(); // Save and close file
    delay(2500);
    lcd.clear();
    flashLed(3); // And flash loop LED 3 times and halt
// LED sequence will blink how ever many times flash variable is set to,
// pause for 2 seconds, then start blink sequence over again indefinitely.
// Number of times LED flashes:
// 1 = SD Card failed or not present
// 2 = Could not create file
// 3 = SD card closed able to remove
void flashLed(byte flash) {
  while (1)  { // while(1) causes program to be stuck in loop forever
    for (byte i = flash; i > 0; i--) {
      digitalWrite(LED_STATUS_PIN, LOW);
      delay(200);
      delay(200);
    delay(2000);
void getSensorData() {
  tpsValue = map(analogRead(TPS_PIN), 82, 900, 0 , 100);
  brakeValue = map(digitalRead(BRAKE_PIN), 0, 1, 0, 100);
  airTemp = map(analogRead(AIR_TEMP_PIN), 798, 143, 10, 120 );
  engTemp = map(analogRead(ENG_TEMP_PIN), 811, 0, 0, 110);
void writeToSdCard() {
      digitalWrite(LED_GPS, HIGH);
      dataFile.print(gps.location.lat(), 6);
      dataFile.print(";");
      dataFile.print(gps.location.lng(), 6);
      dataFile.print(gps.altitude.meters());
      dataFile.print(gps.speed.kmph());
      dataFile.print(tpsValue);
      dataFile.print(brakeValue);
      dataFile.print(airTemp);
      dataFile.print(engTemp);
      dataFile.print(gps.time.value());
      dataFile.println();
      dataFile.flush(); // Save file, but doesn't close
      Serial.println(gps.location.lat(), 6);
      Serial.println(gps.time.value());
void setLCD() {
  //Inicio de la pantalla LCD
  lcd.begin (16, 2);   // Inicializar el display con 16 caraceres 2 lineas
  lcd.setBacklightPin(3, POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home ();
void displayInfo() {
  lcd.setCursor(0,0);
  lcd.print(F("T"));
  lcd.setCursor(0,1);
  lcd.print(F("B"));
  lcd.setCursor(8,0);
  lcd.print(F("I"));
  lcd.setCursor(8,1);
  lcd.print(F("W"));
  lbg.drawValue(tpsValue, 100);
  lbg1.drawValue(brakeValue, 100);
  lbg2.drawValue(airTemp, 120);
  lbg3.drawValue(engTemp, 110);
Where is the problem?
Thanks
"the problem" being that the GPS works?
    do
      displayInfo();
Explain this? You pass the same character to the encode() method over and over. The character either completes a sentence (encode() returns true) or it doesn't (encode() returns false). Why you want to display the same data over and over and over forever when the sentence is complete is a mystery.
