Racking my head...RFIDs not working correctly with this script. Help!
Racking my head against the wall on this one. I have 8 RFIDs connecting to a Mega and only one is registering. Not sure if my script is causing the problem. ideas?
  • This sketch uses the MFRC522 library ; see GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
  • for further details and other examples.
  • NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
  • Typical pin layout used:
  • MFRC522 Arduino Arduino Arduino Arduino Arduino
  • Reader/PCD Uno Mega Nano v3 Leonardo/Micro Pro Micro
  • Signal Pin Pin Pin Pin Pin Pin
  • RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
  • SPI SS SDA(SS) 10 53 D10 10 10
  • SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
  • SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
  • SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define RST_PIN 5 // Configurable, see typical pin layout above // was 9
#define SS_PIN_1 53 // Configurable, see typical pin layout above // was 10
#define SS_PIN_2 2 // Configurable, see typical pin layout above // was 8
#define SS_PIN_3 3 // Configurable, see typical pin layout above
#define SS_PIN_4 4 // Configurable, see typical pin layout above
#define NR_OF_READERS 4
#define NR_OF_KEYES 4
int RELAY_CH = {45, 46, 47, 48}; // Was: 2, 3
int NUM_RELAY_CH = 4;
#define BUTTON 4
byte ssPins = {SS_PIN_1, SS_PIN_2, SS_PIN_3, SS_PIN_4};
// format = {SS_PIN_1, SS_PIN_2, SS_PIN_3, etc.}
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
bool finished = false;
bool in_progress = false;
bool reader1_triggered = false;
bool reader1_complete = false;
bool reader2_triggered = false;
bool reader2_complete = false;
bool reader3_triggered = false;
bool reader3_complete = false;
bool reader4_triggered = false;
bool reader4_complete = false;
String ok_RFID_reader1 = “b09b894d”;
String ok_RFID_reader2 = “60f71b83”;
String ok_RFID_reader3 = “e6a0227e”;
String ok_RFID_reader4 = “10dc1783”;
String RFID_whitelist = {“b09b894d”, “60f71b83”, “e6a0227e”, “10dc1783”}; // Add as many as needed
String read_rfid;
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
SPI.setClockDivider(SPI_CLOCK_DIV128);
//MFRC522.MFRC522_SPICLOCK = SPI_CLOCK_DIV4;
pinMode(BUTTON, INPUT);
for(uint8_t i=0; i<NUM_RELAY_CH; i++) {
pinMode(RELAY_CH*, OUTPUT);*
pinMode(RELAY_CH*, LOW);
_
}_
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card*
* Serial.print(F("Reader "));*
* Serial.print(reader);*
* Serial.print(F(": "));*
* mfrc522[reader].PCD_DumpVersionToSerial();
_
delay(200);_
_
}_
_
}_
_
// Convert card UID to string*_
void dump_byte_array(byte buffer, byte bufferSize) {
read_rfid="";
_
for (byte i = 0; i < bufferSize; i++) {_
read_rfid=read_rfid + String(buffer, HEX);
_ }
void loop() {_
_ // Look for new cards*
* if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {*
* Serial.print(F(“Reader “));
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(”: Card UID:”));_
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.println(read_rfid);
_ // Stop encryption on PCD*
* mfrc522[reader].PCD_StopCrypto1();
authenticate_Card(reader, read_rfid);*
* delay(800);
int button1 = digitalRead(BUTTON);
if(button1 == HIGH) {_
// Activate RELAY_CH*
* // Ruler Pillar Light Function*
* if(reader1_triggered) {
* digitalWrite(RELAY_CH[0], HIGH);
_ }_
if(reader2_triggered) {
* digitalWrite(RELAY_CH[1], HIGH);
_ }_
if(reader3_triggered) {
* digitalWrite(RELAY_CH[2], HIGH);
_ }_
if(reader4_triggered) {
* digitalWrite(RELAY_CH[3], HIGH);
_ }
}_
void authenticate_Card(int reader_id, String uid) {
in_progress = true;
if(reader_id == 0) {
if(uid == ok_RFID_reader1) {
_ Serial.println(“Authenticated Ruler 1”);_
reader1_triggered = true;
_ // Light response handled in loop()
}_
if(reader_id == 1) {
if(uid == ok_RFID_reader2) {
_ Serial.println(“Authenticated Ruler 2”);_
reader2_triggered = true;
}_
if(reader_id == 2) {
if(uid == ok_RFID_reader3) {
_ Serial.println(“Authenticated Ruler 3”);_
reader3_triggered = true;
}_
if(reader_id == 3) {
if(uid == ok_RFID_reader4) {
_ Serial.println(“Authenticated Ruler 4”);_
reader4_triggered = true;
else {_
for(uint8_t i = 0; i < NR_OF_KEYES; i++) {
reader1_complete = true;
_ }
// Turn off ruler lights*
* }_
reader2_complete = true;
_ }
* }_
reader3_complete = true;
_ }
* }_
reader4_complete = true;
_ }
* }*_
void resetPuzzle() {
* finished = false;*
* reader1_complete = false;
_ // Turn off ruler lights handled in loop() section*
void dataPacket(int slaveID, byte data) {
Wire.beginTransmission(slaveID);
Wire.write(data);
delay(100);
Wire.endTransmission();
void receiveEvent(int howMany) {
int inChar;
while(Wire.available() > 0) {
inChar = Wire.read();
if(inChar == 299) {
resetPuzzle();
Serial.println(inChar);
void requestEvent() {_
if(reader1_complete and reader2_complete) {
_ finished = true;
// Just for show test*
* if(reader1_triggered and reader2_triggered) {
in_progress = false;*
* finished = true;
// End test*
* if(in_progress) {*
* Serial.println(253);
if(finished) {
Serial.println(251);
else {
Serial.println(250);
delay(100);
/_
Hello - please Use code tags - your code is in italics meaning somewhere a [i] array index got interpreted as 'set text in italic' and nothing makes sense
What's the intent of pinMode(RELAY_CH[i], LOW);have you seen pinMode used like this before?
Have you tried with separate reset pins for each reader?
(I've seen other run in problems with this and no solution)
