As you see from the topic , i am trying to build a radar with these equipments.
(this just a test code , i am working on it)
my range will be between 5cm-30cm . otherwise it will accepted as zero.
i got several problems.
-my measured distances will keep in an array that is " mesafe[pos] "
normally if an distance out of my limits (5cm-30cm) it must be zero. But i have value of 4 at my arrays.
coordinates of my radar circle (x,y) = (200,120), radius = 15
i mapped my calculated coordinates calues to the radar circle
(1-measure the first distance when an object has seen
use the value of angle for first distance
2- measure the second distance when an object has seen
3- calculate the maps location from (1) and (2) then map to the radar screen. ) -
my results places only at horizontal exis (x axis) , (that is the main problem)
consider the first hal circle (degree: zero to 180)
// 15.09.2014
// gokhan mavi ekran
// UTFT_Demo_320x240 (C)
// 2014 Gokhan OZTURK
// web: http://ozturkgokhan.com/
// This was made for modules with a screen resolution
// of 320x240 pixels.
#include <UTFT.h>
#include <stdio.h>
#include <Servo.h> //---------------------------------- servo setup
float x_coordinate=0,y_coordinate=0;
float x_coordinate2=0,y_coordinate2=0;
float objectx=0, objecty=0, objectc=0;
int xmin=0, xmax=0, ymin=0, ymax=0;
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0, pos_i1, pos_i2, pos_f1, pos_f2; // variable to store the servo position
int ultrasonic2TrigPin[2] = { A8, A10 }; //
int utlrasonic2EchoPin[2] = { A9, A11 };
int m=0,f;
float mesafe[181] ={ 0 };
float mesafe2[181] ={ 0 };
extern uint8_t SmallFont[];
UTFT myGLCD(SSD1289,38,39,40,41);
int x=0;
pinMode(ultrasonic2TrigPin[0], OUTPUT);
pinMode(utlrasonic2EchoPin[0], INPUT);
pinMode(ultrasonic2TrigPin[1], OUTPUT);
pinMode(utlrasonic2EchoPin[1], INPUT);
myservo.attach(A7);
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
myGLCD.clrScr();
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 319, 13);
myGLCD.setColor(0, 0, 0);
myGLCD.setBackColor(255,255,255);
myGLCD.print("Gokhan OZTURK", 12, 18); // yaz?,xdeki ba?lang?ç, ydeki ba?lang?ç
myGLCD.print("21177112", 12, 31);
myGLCD.print("Hacettepe", 12, 44);
myGLCD.print("University", 12, 56);
myGLCD.print("Electronics", 12, 69);
myGLCD.print("Engineering", 12, 81);
myGLCD.print("Basic Radar Project", 150, 18);
myGLCD.setColor(160, 160, 160);
myGLCD.drawRoundRect(3, 16, 120, 236); // sol kare
myGLCD.drawRoundRect(124, 16, 318, 236); // sa? kare
myGLCD.drawCircle(220,120,80); // radar daire
myGLCD.drawLine(220,40,220,200); // dik çizgi
myGLCD.drawLine(140,120,300,120); // yatay çizgi
//myGLCD.setColor(255, 255, 0); // detected object
//myGLCD.fillCircle(200,120,15); // radar daire
for(pos = 0; pos <= 180; pos += 1){ // goes from 0 degrees to 180 degrees // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
if(mesafe_olc(m) >= 5 && mesafe_olc(m) <= 30){
mesafe[pos] = mesafe_olc(m); // save distance to mesafe[pos] if distance is betweeen 5 and 30
else{
mesafe[pos] = 0; // save 0 to mesafe[pos] if distance is not betweeen 5 and 30
if (mesafe[pos] != 0){
pos_i1 = pos; // pos_i1 is equal to pos if mesafe[pos] is not equal to 0
for(pos = pos_i1; pos <= 180; pos += 1){
if (mesafe[pos] == 0){
pos_f1 = pos; // pos_f1 is equal to pos if mesafe[pos] is equal to 0
radar (mesafe[pos_i1],pos_i1,&x_coordinate,&y_coordinate);
radar (mesafe[pos_f1],pos_f1,&x_coordinate2,&y_coordinate2);
radarm (x_coordinate,x_coordinate2,y_coordinate,y_coordinate2,&objectx,&objecty,&objectc);
myGLCD.fillCircle(objectx,objecty,objectc);
// else {
// myGLCD.setColor(255, 255, 255); // ekrana siyah nokta basar, bo? yani
// myGLCD.fillCircle(210,220,0);
for(pos = 180 ; pos >= 0 ; pos -= 1) // goes from 180 degrees to 0 degrees
{ // in steps of 1 degree
mesafe2[pos] = mesafe_olc(m); // save distance to mesafe[pos] if distance is betweeen 5 and 30
else{
mesafe2[pos] = 0; // save 0 to mesafe[pos] if distance is not betweeen 5 and 30
for(pos = 180 ; pos >= 0 ; pos -= 1){
if (mesafe2[pos] != 0){
pos_i2 = pos; // pos_i2 is equal to pos if mesafe2[pos] is not equal to 0
for(pos = pos_i2; pos >= 0 ; pos -= 1){
if (mesafe2[pos] == 0){
pos_f2 = pos; // pos_f2 is equal to pos if mesafe2[pos] is equal to 0
radar (mesafe2[pos_i2],pos_i2,&x_coordinate,&y_coordinate);
radar (mesafe2[pos_f2],pos_f2,&x_coordinate2,&y_coordinate2);
// else {
//radar alt progam?
void radar (float a, float b, float *c, float *d){
*c=a*cos((b*PI)/180);
*d=a*sin((b*PI)/180);
*c = map(*c, -80, 80, 140,300);
*d = map(*d, -80, 80, 40, 200);
// void radarf (float a, float b, float *c2, float *d2){
// *c2=a*cos((b*PI)/180);
// *d2=a*sin((b*PI)/180);
// *c2 = map(*c2, -80, 80, 140 ,300);
// *d2 = map(*d2, -80, 80, 40 , 200);
void radarm (float x_coordinate, float x_coordinate2, float y_coordinate, float y_coordinate2, float *objectx, float *objecty, float *objectc ){
float xmin= 0 , xmax = 0, ymin = 0, ymax = 0;
xmin = min(x_coordinate, x_coordinate2);
xmax = max(x_coordinate, x_coordinate2);
ymin = min(y_coordinate, y_coordinate2);
ymax = max(y_coordinate, y_coordinate2);
*objectx = (((xmax-xmin)/2)+xmin);
*objecty = ((ymax-ymin)/2)+ymin;
*objectc = min(((ymax-ymin)/2),((xmax-xmin)/2)) ;
int mesafe_olc ( int m){ //m is the trig no
int ultrasonic2Duration = 0, ultrasonic2Distance = 0;
digitalWrite(ultrasonic2TrigPin[m], HIGH);
delayMicroseconds(10); // must keep the trig pin high for at least 10us
digitalWrite(ultrasonic2TrigPin[m], LOW);
ultrasonic2Duration = pulseIn(utlrasonic2EchoPin[m], HIGH);
ultrasonic2Distance = (ultrasonic2Duration/2)/29;
return ultrasonic2Distance;
