Radice quadrata e floating point
Ciao, sto facendo un pò di esperimenti con la radice quadrata:
void setup(){
  Serial.begin(57600);
void loop(){
  Serial.println("Starting long calculation:");
  start();
  int a;
  unsigned long t;
  float ris=0;
  t = micros();
  for (a=0;a<6000;a++){
    ris+=a;
  t=micros()-t;
  Serial.println(ris);
  Serial.print("Time for:");
  Serial.println(t);
  t = micros();
    ris+=sqrt(a);
    //Serial.print(ris);
  Serial.print("Time sqrt:");
  Serial.println(t);
  t = micros();
    ris+=Q_rsqrt(a);
//    Serial.print(ris);
  t=micros()-t;
  Serial.print("Time Q_rsqrt:");
  Serial.println(t);
  t = micros();
    ris+=Q_rsqrt2(a);
  t=micros()-t;
  Serial.print("Time Q_rsqrt2:");
  Serial.println(t);
void start(){
  double diff;
  double maxDiff=0;
  double midDiff=0;
  double maxDiff2=0;
  double midDiff2=0;
  long count=0;
  float a;
  for (a=0;a<1000;a+=0.01){
    //printf("ciclo: %d e %f\n", count, a);
    count++;
    diff = (float)( sqrt(a) ) - 1.0/Q_rsqrt(a);
    midDiff+=diff;
    if (abs(diff)>maxDiff){
      maxDiff=abs(diff);/*
      Serial.print("1_diff is:");
      Serial.print(diff);
      Serial.print(" at:");
      Serial.println(a);*/
    diff = (float)( sqrt(a) ) - 1.0/Q_rsqrt2(a);
    midDiff2+=diff;
    if (abs(diff)>maxDiff2){
      maxDiff2=abs(diff);/*
      Serial.print("2_diff is:");
      Serial.print(diff);
  Serial.print("maxdiff is:");
  if (maxDiff!=0)
    Serial.println(maxDiff, 7);
    Serial.println("nodiff");
  Serial.print("middiff is:");
  Serial.println(midDiff/count, 7);
  Serial.print("maxdiff2 is:");
  if (maxDiff2!=0)
    Serial.println(maxDiff2, 7);
  Serial.print("middiff2 is:");
  Serial.println(midDiff2/count, 7);
float Q_rsqrt( float number ){
        long i;
        float x2, y;
        const float threehalfs = 1.5F;
        x2 = number * 0.5F;
        y  = number;
        i  = * ( long * ) &y;                       // evil floating point bit level hacking
        i  = 0x5f3759df - ( i >> 1 );               // what the fuck?
        y  = * ( float * ) &i;
        y  = y * ( threehalfs - ( x2 * y * y ) );   // 1st iteration
 //   y  = y * ( threehalfs - ( x2 * y * y ) );   // 2nd iteration, this can be removed
        return y;
float Q_rsqrt2( float number ){
        long i;
        float x2, y;
        x2 = number * 0.5F;
        y  = number;
        return y;
risultati:
maxdiff is:0.0542393
middiff is:-0.0204092
maxdiff2 is:0.0001450
middiff2 is:-0.0000408
Time for:72752
Time sqrt:61048312
Time Q_rsqrt:317052
Time Q_rsqrt2:537008
Time for:72752
Time sqrt:124226644
Time c:317052
Time Q_rsqrt2:537012
dopo varie iterazioni, sqrt si assesta intorno a 566477768
cosa si evince?
  1. l'uso di SQRT ha tempi molto variabili, forse c'è una componente random?
  2. l'uso di Q_rsqrt è dal 200% al 1800% più veloce, però con una pesante perdita di precisione
  3. l'uso di Q_rsqrt2 è dal 100% al 1000% più veloce, con perdita minima della precisione
l'algoritmo non è mio, ma quello usato in Quake3. Notare che Q_rsqrt e Q_rsqrt2 NON sono la radice quadrata, ma l'inversa, ovvero 1/sqrt(), molto utile se usata per normalizzare dei vettori
se vi chiedete perchè stampo Serial.println(ris); è perchè se no il compilatore si accorge che i for non servono nulla ai fini del programma e bellamente non li esegue nemmeno (4 millisecondi fissi per tempo for, sqrt, etc..)
output(lungo):
17996896.00
Time for:72752
309799.53
Time sqrt:187369712
0.00
Time Q_rsqrt:317060
0.00
Time Q_rsqrt2:537016
17996896.00
Time for:72752
309799.53
Time sqrt:218951880
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:250534052
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:282116220
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:313698396
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:345280564
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:376862736
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:408444904
0.00
Time Q_rsqrt:317060
0.00
17996896.00
Time for:72752
309799.53
Time sqrt:440027084
0.00
Time Q_rsqrt:317060
0.00
Bell'esperimento....
Soprattutto perchè permette di vedere la più veloce e precisa :slight_smile:
ora sarebbe da confrontarla in termini di tempo e precisione con quella messa a disposizione dall' IDE no ?
sono in confronto con quella dell'ide (SQRT)!
mi pareva si scrivesse in una altro modo.. boh ricorderò male mi pareva fose una funzione ho visto male...
