HI All,
As part of a project I’m working on I need to read data being sent to a 15-CHARACTER 1-LINE DOT MATRIX LCD CONTROLLER DRIVER with OUTPUT PORT - NJU6623 Data Sheet
The aim will be to use a MEGA2560 as a slave. Read the code its being sent and when it picks up a certain character being sent to the DDRAM address 0x80 start sending different data to the screen.
I have the below code for writing to the screen. This works when directly hooked up to the screen.
#include <SPI.h>
#include <Time.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS3231 rtc;
//PORTB
#define DATAOUT 51 // MOSI
#define SPICLOCK 52 //sck
#define ssPin 53 // PB0
//PORT L
#define mode0 49
#define mode1 48
// User configurable
String welcome = "TEST"; // populate something into the text display - 12 Char max anything else is truncated.
// Control pins for the display SPI
pinMode(mode0, OUTPUT);
pinMode(mode1, OUTPUT);
pinMode(ssPin, OUTPUT);
// Real time clock
rtc.begin();
rtc.adjust(DateTime(2020, 4, 01, 13, 54, 0)); //a fixed time
SPI.begin();
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3)); //I couldn't see a defined max speed in the NJU6623 datasheet, 10Meg is quite an increase on the original 9600, so need to monitor incase this is not stable.
Serial2.begin (4800, SERIAL_8E1);
populateFixedLcdDisplay(welcome);
// LCD Display
void populateFixedLcdDisplay(String _lcdInput)
_lcdInput.remove(12);
if (_lcdInput.length() < 12)
for (byte i = _lcdInput.length() + 1; i <= 12; i++)
_lcdInput.concat(' ');
byte _start = 0x80;
PORTB &= ~(1 << PB0);
SPI.transfer(0x80);
PORTB |= (1 << PB0);
for (byte i = 0; i < _lcdInput.length(); i++)
PORTL |= (1 << PL0);
SPI.transfer(_lcdInput.charAt(i));
delayMicroseconds(42);
PORTL &= ~(1 << PL0);
As I don’t have a spare Radio ( the device that currently populates the display) I’ve set up an Uno to act as a slave and read what the above code is sending out so I can test its all working before fitting.
Currently my slave code below kind of reads from the above code but only if i sent certain text that ends in :
#include <SPI.h>
char buff [50];
volatile byte indx;
volatile boolean process;
void setup (void) {
Serial.begin (9600);
SPI.setDataMode(SPI_MODE3);
pinMode(MISO, OUTPUT); // have to send on master in so it set as output
SPCR |= _BV(SPE); // turn on SPI in slave mode
indx = 0; // buffer empty
process = false;
SPI.attachInterrupt(); // turn on interrupt
ISR (SPI_STC_vect) // SPI interrupt routine
byte c = SPDR; // read byte from SPI Data Register
if (indx < sizeof buff) {
buff [indx++] = c; // save data in the next index in the array buff
if (c == ':') //check for the end of the word
process = true;
void loop (void) {
if (process) {
process = false; //reset the process
Serial.println (buff); //print the array on serial monitor
indx= 0; //reset button to zero
How do I modify the slave to read a single CGRAM character being sent to 0x80 of the DDRAM?
