Radio code appears to be interfering with other functions.
At 1 sec intervals the effect on the PID is now negligable, although it may be of benefit at very low rpm. Not sure how to go about ignoring the computation after exchangeData though.
I still have a problem where the message from hand controller to master has approx 3 second lag. If I reduce
unsigned long txIntervalMillis = 1000;
the lag improves considerably but it then interferes with the PID but at least it indicates that the problem is at the server end.
Master code.
  Arduino Nano
  Pin allocation:
  D1
  D2 = speed sensor (interrupt 0)
  D3 = Ping trigger
  D4 = Ping Echo
  D5 = ESC relay
  D6 = ESC PWM out
  D7 = Radio CE
  D8 = Radio CSN
  D9 =
  D10 =
  D11 = Radio
  D12 = Radio
  D13 = Radio
  A0 = Current sensor
  A1 =
  A2 =
  A3 =
  A4 =
  A5 =
  A6 =
  A7 =
//*********Height Sensor Stuff*********
#include <NewPing.h>
#define TRIGGER_PIN  3  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     4  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
int dist;
//*****Motor Controller Stuff******
#include <PID_v2.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, 0.6, 6.2, .01, DIRECT);
#define PWMpin  6
volatile unsigned long timeX = 1;
int PulsesPerRevolution = 36;
int MaxRPM = 400;
volatile int Counts = 1;
double PulsesPerMinute;
volatile unsigned long LastTime;
volatile int PulseCtr;
unsigned long Counter;
int startRamp;
unsigned long Time;
int rpm;
int printRpm; // Averaged over several readings to smooth it out.
volatile int rpmArray[5] = {0, 0, 0, 0, 0}; // For printRpm
//********Radio Stuff*******
#include <nRF24L01.h>
#include <RF24.h>
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   7
#define CSN_PIN 8
// NOTE: the "LL" at the end of the constant is "LongLong" type
// These are the IDs of each of the slaves
const uint64_t slaveID[2] = {0xE8E8F0F0E1LL, 0xE8E8F0F0E2LL} ;
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
int radioTxArray[2];
unsigned long currentMillis;
unsigned long prevMillis;
int txVal = 0;
int radioRxArray[6];
//0 = motor on/off, 1 = setPoint, 2 = , 3 = Height, 4 = Cal, 5 = Dist
byte radioRxArrayLen = 12; // NB this 4 is the number of bytes in the 2 ints that will be recieved
bool isStarted = false;
bool isCal = false;
bool isDist = false;
bool go = false;
  // note that 1666666.67 = (60 seonds * 1000000 microseconds)microseconds in a minute / (36 / 9) pulses in 1 revolution
  PulsesPerMinute = (60 * 1000000) / (PulsesPerRevolution / Counts);
  pinMode(2, INPUT_PULLUP);
  Serial.println("PID controlled Seeder Master R0");
  //Digital Pin 2 Set As An Interrupt for tacho.
  attachInterrupt(0, sensorInterrupt, FALLING);
  startRamp = 10;//map(PulsesPerRevolution , 1, MaxRPM, MaxRPM, 2);
  myPID.SetSampleTime(1);
  myPID.SetOutputLimits(40, (int) 255);
  PulseCtr = 0;
  myPID.SetMode(AUTOMATIC);
  analogWrite(PWMpin, 60);
  myPID.Compute();
  delay(11);
  myPID.Compute();
  radio.begin();
  radio.setDataRate( RF24_250KBPS );
  radio.enableAckPayload();
  radio.setRetries(3, 5); // delay, count
  exchangeData();
  getSetPoint();
  getStartStop();
  getHeight();
  readMotorCurrent();
  switchOnOff();
  readRpm();
  debug();
  static unsigned long SpamTimer;
void exchangeData()
  currentMillis = millis();
  if (currentMillis - prevMillis >= txIntervalMillis) {
    radio.openWritingPipe(slaveID[0]); // calls the first slave
    // there could be a FOR loop to call several slaves in turn
    bool rslt;
    rslt = radio.write( radioTxArray, sizeof(radioTxArray) );
    if ( radio.isAckPayloadAvailable() ) {
      radio.read(radioRxArray, radioRxArrayLen);
    prevMillis = millis();
void getSetPoint()
  if (isStarted == true) {
    Setpoint = radioRxArray[1];
    // Setpoint = 30;
    Setpoint = 0;
    radioTxArray[0] = 0;
void getStartStop()
  if (radioRxArray[0] == 1) //start/stop button on.
    if (radioRxArray[3] == 0) //height switch off.
      isStarted = true;
    if (dist <= radioRxArray[5] && radioRxArray[3] == 1) //if ping dist is less than dist set point and height switch is on.
      isStarted = true;
    isStarted = false;
void getHeight()
  unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
  dist = (uS / US_ROUNDTRIP_CM); //raw distance in cm.
void readMotorCurrent()
void switchOnOff()
    digitalWrite(5, HIGH);
    digitalWrite(5, LOW);
void sensorInterrupt()
  static int Ctr;
  unsigned long Time;
  Ctr++;
  if (Ctr >= Counts) { // 36 / 4 = 9 so we are taking an average of 9 readings to use in our calculations
    Time = micros();
    timeX += (Time - LastTime); // this time is accumulative ovrer those 9 readings
    LastTime = Time;
    PulseCtr ++;
    Ctr = 0;
void readRpm()
  cli ();         // clear interrupts flag
  Time = timeX;   // Make a copy so if an interrupt occurs timeX can be altered and not affect the results.
  timeX = 0;
  sei ();         // set interrupts flag
  if (PulseCtr > 0) {
    Input =  (double) (PulsesPerMinute /  (double)(( (unsigned long)Time ) *  (unsigned long)PulseCtr)); // double has more percision
    //   PulseCtr = 0; // set pulse Ctr to zero
    // debug();
    if (!myPID.Compute()); //Serial.println();
    analogWrite(PWMpin, Output);
    Time = 0; // set time to zero to wait for the next rpm trigger.
    Counter += PulseCtr;
    // we are automatically adjusting the diviser to preserve processor time after calculating last rpm
    // starting at 0 RPM ~ 400+RPM we adjust the division of the pulses per revolution
    // Counts = 100; constrain(map((int)Input, startRamp, MaxRPM, 1, PulsesPerRevolution), 1, PulsesPerRevolution);
    PulsesPerMinute = (60.0 * 1000000.0) / (double)((double)PulsesPerRevolution / (double)Counts);
    //Fill rpm array with rpm readings and average them for display.
    rpmArray[0] = rpmArray[1];
    rpmArray[1] = rpmArray[2];
    rpmArray[2] = rpmArray[3];
    rpmArray[3] = rpmArray[4];
    rpmArray[4] = Input;
    //Last 5 Average RPM Counts Eqauls....
    printRpm = (rpmArray[0] + rpmArray[1] + rpmArray[2] + rpmArray[3] + rpmArray[4]) / 5;
    radioTxArray[0] = printRpm;//average sent to hand controller
void debug()
    Serial.print("\nRSLT (1 = success) ");
    Serial.println(rslt);
    Serial.print("Data Sent ");
    Serial.print(radioTxArray[0]);
    Serial.print("  ");
    Serial.println(radioTxArray[1]);
    char S[20];
    if ((unsigned long)(millis() - SpamTimer) >= 100) {
    SpamTimer = millis();
    Serial.print(" rpm: "); Serial.print(Input );
    Serial.print(" motor: "); Serial.print(radioRxArray[0]);
    Serial.print(" setpoint: "); Serial.print(radioRxArray[1]);
    Serial.print(" height "); Serial.print(radioRxArray[3]);
    Serial.print(" cal: "); Serial.print(radioRxArray[4]);
    Serial.print(" dist: "); Serial.print(radioRxArray[5]);
    Serial.print(" ping sensor "); Serial.println(dist);
Robin2: From the examples you posted it seems that only one PID calculation is affected by reading the wireless. I just wondered if you could ignore that particular PID calcluation.
...R
The more I think about this, the better it sounds. I would like to try it but how?
Perhaps I should have explained somewhere that I only had the 1 second interval for demo purposes. I normally run that code with an interval of 100 millisecs (i.e. about 10 times per second). At that rate I am not conscious of any latency.
Post the complete program and I will see if I can figure out how you might ignore a particular calculation - or why there are glitches in the first place.
...R
I think you are on track with the skip the input after transmission since the NEW PID routine does not require a fixed time interval (delta T). It only requires an instantaneous reading to calculate the next PID output. The minimal delay will not affect the calculation in any way
Try adding This:
// up top
bool Skip = false;
// in void exchangeData() when you are successful
Skip = true;
// in void readRpm()
   if(!Skip) { //PID only needs an instantaneous reading and so if we skip a few no harm done since Delta T is no longer a fixed value
      if (!myPID.Compute()) Serial.println();
   else Skip = false;
Glad to be back, I missed the shift to this thread and I was hoping all was going well for you. It looks like you are close to completion. let me know if this works.
Thankyou both for the help.
How is your project going zhomeslice?
I added the changes you suggested zhomeslice and it seems to stop the interference from the radio.
However, when I reduce txIntervalMillis below about 300, the Motor start is very delayed and if I reduce it to 100, the motor will not start at all. 400 is about the minimum usable interval.
  Arduino Nano
  Pin allocation:
  D1
  D3 = Ping trigger
  D4 = Ping Echo
  D5 = ESC relay
  D6 = ESC PWM out
  D7 = Radio CE
  D8 = Radio CSN
  D9 =
  D10 =
  D11 = Radio
  D12 = Radio
  D13 = Radio
  A0 = Current sensor
  A1 =
  A2 =
  A3 =
  A4 =
  A5 =
  A6 =
  A7 =
int dist;
#include <PID_v2.h>
#define PWMpin  6
int MaxRPM = 400;
int startRamp;
unsigned long Time;
int rpm;
#include <RF24.h>
#include <SPI.h>
#include <RF24.h>
#define CE_PIN   7
#define CSN_PIN 8
unsigned long txIntervalMillis = 100;
int txVal = 0;
bool isCal = false;
bool go = false;
bool Skip = false;
  PulseCtr = 0;
  myPID.Compute();
  delay(11);
  myPID.Compute();
  radio.begin();
  rf24_pa_dbm_e{RF24_PA_MAX};
  exchangeData();
  getSetPoint();
  getStartStop();
  getHeight();
  readMotorCurrent();
  switchOnOff();
  readRpm();
  debug();
void exchangeData()
    bool rslt;
      Skip = true;
void getSetPoint()
    // Setpoint = 30;
    Setpoint = 0;
void getStartStop()
      isStarted = true;
      isStarted = true;
    isStarted = false;
void getHeight()
void switchOnOff()
  static int Ctr;
  unsigned long Time;
  Ctr++;
    Time = micros();
    LastTime = Time;
    PulseCtr ++;
    Ctr = 0;
void readRpm()
  timeX = 0;
  if (PulseCtr > 0) {
    // debug();
    if (!Skip) { //PID only needs an instantaneous reading and so if we skip a few no harm done since Delta T is no longer a fixed value
    else Skip = false;
void debug()
    Serial.print("  ");
    char S[20];
Lets slow down the need to trigger the PID loop and set a more even interval
I’ve tested this and it works great. After you started perusing the communications side of things I had one more itch I had to scratch on the tachometer code. and now after you made these points I think it is worth including in you code.
What it does is automatically adjust the number of triggering counts that need to take place before triggering the PID loop. you have a desired goal that you will set and the program adjusts to meet the request.
benefits are that you can decrease speed of your motor to a slow rpm and maintain a responsive PID loop
Here is the code:
// Add this near the top of the sketch
int SampleDuration = 20; // in Milliseconds I used 10 but I was testing for overall workload
// 20 I thing will work well for you bur 100 could also be good
// What this does is set the desired duration
// updated code
void readRpm()
  timeX = 0;
  if (PulseCtr > 0) {
    // debug();
    else Skip = false;
   // <<<<<<<<<<<<<<<<<<<<<<<<<<<< the following 3 lines perform the adjustments
    if(Time > ((SampleDuration + 1)*1000))Counts--;
    if(Time < ((SampleDuration - 1)*1000))Counts++;
    Counts = constrain(Counts, PulsesPerRevolution * .1,PulsesPerRevolution *4);
Try this first and let me know if it helps.
I believe we could breakup the exchangeData routine to transmit the RPM fast but make changes in a slower manner
guessing at the 500 interval it may be too slow… testing is necessary :slight_smile:
unsigned long prevMillisRX, prevMillisTX;
unsigned long rxIntervalMillis = 500;
void exchangeData()
  if (currentMillis - prevMillisTX >= txIntervalMillis) {
    bool rslt;
    prevMillisTX = currentMillis;
  if (currentMillis - prevMillis >= rxIntervalMillis) {
      Skip = true;
I’m not a big fan of #include <NewPing.h>
due to a while() loop that traps any further execution of code till it is freed when the ping returns.
Your code is locked from the start of the trigger pin rise to the end of the echo pin drop and can’t do anything else while it is holding hostage your arduino
I have a working PING code that will remedy this multiple while loop issue NewPing has
Are you using more than one ping sensor… would you like to use more than one?
I think if we have more time for the radio its abuse of time will be less noticeable :slight_smile:
You have some great ideas there. I am at work for another few hours so no testing yet but I am keen to try the revised tacho.
I can only see the use for one ping sensor so I think we can lock it in at that.
I also need to stop the motor on is started = false but ATM the output 40 - 255 prevents the motor from stopping. I need to give this some more thought.
moose4621: I can only see the use for one ping sensor so I think we can lock it in at that.
I'll adjust my code for 1 ping sensor and simplify it to fit. this should be easy :)
you could just put it in manual and force the output to zero.
//  you can do something like
 if (Stop = ture){
    myPID.SetMode(MANUAL);
    Output = 0;
    analogWrite(PWMpin, Output); // Stop NOW
 else if(myPID.GetMode() == MANUAL) myPID.SetMode(AUTOMATIC); // only change to automatic if it has been set to manual to save processor time
I am grinning from ear to ear. Your ideas and suggestions are great. I am looking forward to getting home to try these out.
I got the ping code completed and tested with only 1 sensor, I'm just cleaning up unused variables.
I'll help out with integration if needed :)
Here you go Ping timer without any waiting for the sound to return
NOTE: I had to swap 2 pins to use the interrupt
  D3 = Ping trigger
  D4 = Ping Echo
  We need to change it to
  D3 = Ping Echo *** The arduino has an easy interrupt on pin 3 that will allow us to simplify my code
  D4 = Ping trigger
#define TriggerPin  4
// echo pin will be interrupt 1 on pin 3
#define DelayBetweenPings 50 // it works to about 5 milliseconds between pings
volatile  unsigned long PingTime;
volatile  unsigned long edgeTime;
volatile  uint8_t PCintLast;
int PinMask = B1000; // pin 3
float Measurements = 0;
void PintTimer( )
  static uint8_t pin;
  static unsigned long cTime;
  cTime = micros();         // micros() return a uint32_t
  pin = PIND; //  get the state of all pins 0-8  quick snap shot
  sei();                    // re enable other interrupts
  uint16_t dTime;
  PCintLast = pin;          // we memorize the current state of all PINs
  int CheckPin = 3;
  if ((pin >> CheckPin & 1))edgeTime = cTime; //Pulse went HIGH store the start time
  else { // Pulse Went low calculate the duratoin
    dTime = cTime - edgeTime; // Calculate the change in time
    PingTime = dTime; // Lets Store any duration up to 65535 micro seconds
  Serial.println("Ping Test");
  pinMode(3, INPUT);
  pinMode(4, OUTPUT);
  attachInterrupt(1, PintTimer, CHANGE );
  PingIt(); // Manage ping data
  debug();
void PingTrigger(int Pin) {
  digitalWrite(Pin, LOW);
  delayMicroseconds(1);
  digitalWrite(Pin, HIGH); // Trigger another pulse
  delayMicroseconds(10);
bool AllClear() {
  return (!(PinMask & PIND)); //  all the input pins are LOW
void PingIt() {
  unsigned long PT;
  static unsigned long PingTimer;
  if ( AllClear()) { // Wait
    if ((unsigned long)(millis() - PingTimer) >= DelayBetweenPings) {
      PingTimer = millis();
      PT = PingTime;
      Measurements = (float) (microsecondsToCentimeters(PT));
//      Measurements = (float) (microsecondsToInches(PT));
      PingTrigger(TriggerPin); // Send another ping
float microsecondsToInches(long microseconds){
  return (float) microseconds / 74 / 2;
float microsecondsToCentimeters(long microseconds){
  return (float)microseconds / 29 / 2;
void debug() {
  char S[20];
  if ((unsigned long)(millis() - PingTimer) >= 100) {
    Serial.print(dtostrf(Measurements, 6, 1, S));
Testing the first tacho mod now. Using the serial debug you have enabled, what values should I be aiming for Kp, Ki, and Kd?
zhomeslice: Here you go Ping timer without any waiting for the sound to return NOTE: I had to swap 2 pins to use the interrupt
Wow, with decimal precision too! Awesome.
moose4621: Testing the first tacho mod now. Using the serial debug you have enabled, what values should I be aiming for Kp, Ki, and Kd?
If you are watching the resulting calculations. I'm assuming you are at setpoint and the PID is tuned. Kp should fluctuate around zero. Ki is additive and will produce an offset so that setpoint can be reached. this moves slower than Kp. Kp + Ki will produce the output PWM input 0~255 to keep the motor at the desired speed. Kd is detailed oriented. It cleans up messes. Sudden change in setpoint/reading will cause Kd value to spike. But it's its influence is short lived.It just speeds up the process of reaching setpoint. (Tune Kd last)
zhomeslice: you could just put it in manual and force the output to zero.
if (Stop = ture){     myPID.SetMode(MANUAL);     Output = 0;     analogWrite(PWMpin, Output); // Stop NOW } else if(myPID.GetMode() == MANUAL) myPID.SetMode(AUTOMATIC); // only change to automatic if it has been set to manual to save processor time
Worked a treat. Had to do the kick start thing again though.
void switchOnOff()
  if (isStarted == false)
    Output = 0;
  else if (myPID.GetMode() == MANUAL)
    myPID.Compute();
    delay(11);
    myPID.Compute();
Thank you for this idea. I would never have come up with this. I was heading down the track of putting a relay in to switch the esc off. This is a much better solution.
Excellent :) I'm glad the ping code works well for you. How does the Ping sensor interact with the setup? Are you using it to adjust the setpoint of the motor when an object gets close? or is it just a status reading?
The ping sensor is used to switch the motor on/off as the 3 point linkage on the tractor is raised and lowered. I will have to give you a better idea of what I want the final outcome to be. Need a video and/or cad drawing to show you. I’ll take some photo’s tomarrow.
zhomeslice:
I see where you are going with this but the problem is that I am not receiving data from the hand held remote (client) fast enough.
The remote has the start stop button of which I need to keep the lag to as little as possible.
The client, if I understand correctly, is continuously transmitting but the master only receives at txIntervalMillis.
Master
void exchangeData()
    bool rslt;
      Skip = true;
Client, (hand held remote).
void exchangeData()  {
radio.writeAckPayload(1, radioTxArray, sizeof(radioTxArray));
  if ( radio.available() ) {
    radio.read( radioRxArray, sizeof(radioRxArray) );
    Serial.print("Data received Number0 ");
    Serial.print(" Number1 ");
    Serial.println(radioRxArray[1]);
I wonder if I am better off reversing the radios?
They are the way they are since adaptation from Robin2's excellent examples.
I see how you are working this. each time the new rpm reading is sent your master unit is expecting an update even if nothing has changed. you need the sensor reading to be responsive. With LCD displays 100 milliseconds is usually enough (10 times a second) so if you were to reverse the roles 1) you need a ping from the remote (Now Master) every x milliseconds to confirm communications is still alive 2) you only need to get the RPM status when you need to update the display 3) you will only need to send updates when you make a change (Push a button etc.) 4) if ping fails have the settings default to a safe condition and send a request to the when communication is restored remote (Now Master) for complete update
this would take a load off the robot (now Slave) UNO and provide you with almost instantaneous responses due to changes would be sent the instant they are detected.
I am avoiding giving you feedback on the new tacho code because I am getting some wild fluctuations from the sensor. :confused: I disabled the radio and ping sensor and wrote a fixed PWM output to the esc to test the results.
output from PID controlled seeder master R2 with fixed analogWrite of 80. Radio & Ping dissabled.
 In  45.42 Setpt  30.00 /\T 1284416.00 Kp -20.04 Ki  10.72 Kd         0 Out 0
 In  49.41 Setpt  30.00 /\T 1214320.00 Kp -25.23 Ki   3.56 Kd         0 Out 0
 In  45.71 Setpt  30.00 /\T 1348988.00 Kp -20.43 Ki   8.07 Kd         0 Out 0
 In  45.42 Setpt  30.00 /\T 1394444.00 Kp -20.04 Ki   7.49 Kd         0 Out 0
 In  58.50 Setpt  30.00 /\T 1111136.00 Kp -37.05 Ki -11.82 Kd         0 Out 0
 In  47.66 Setpt  30.00 /\T 1398832.00 Kp -22.96 Ki   1.41 Kd         0 Out 0
 In  42.84 Setpt  30.00 /\T 1595056.00 Kp -16.69 Ki   9.43 Kd         0 Out 0
Obviously the pid's are irrelevant but the fluctuation in input is a problem. I disassembled the sensor and rotor and cleaned them and checked wiring but I cannot find where the fluctuation is coming from.
Using this basic sensor test;
volatile float time = 0;
volatile float time_last = 0;
volatile int rpm_array[5] = {0, 0, 0, 0, 0};
int pot;
  attachInterrupt(0, fan_interrupt, FALLING);
  // pot = analogRead(0);
  analogWrite(6, 100);
//Main Loop To Calculate RPM and Update LCD Display
  while (1) {
    //analogWrite(6, map(pot, 0,1023, 0, 255));
    int rpm = 0;
    //Slow Down The LCD Display Updates
    delay(400);
    //Update The RPM
      noInterrupts();
      unsigned long copyTime = time;
      interrupts();
    if (time > 0)
      //5 Sample Moving Average To Smooth Out The Data
      rpm_array[0] = rpm_array[1];
      rpm_array[1] = rpm_array[2];
      rpm_array[2] = rpm_array[3];
      rpm_array[3] = rpm_array[4];
      rpm_array[4] = 60 * (1000000 / (time * 36));
      rpm = (rpm_array[0] + rpm_array[1] + rpm_array[2] + rpm_array[3] + rpm_array[4]) / 5;
      // rpm = 60*(1000000/(time * 36));
      Serial.print(rpm);
      Serial.print("  ");
      Serial.println(pot);
//Capture The IR Break-Beam Interrupt
void fan_interrupt()
  time = (micros() - time_last);
  time_last = micros();
I get;
2  0
43  0
43  0
43  0
50  0
50  0
50  0
50  0
50  0
42  0
42  0
42  0
42  0
I need to fix this first but it's after midnight. No more running motors tonight or I will get divorced. :(
