radio communication with pcb antennas
hi, i need some help to find a radio device with integrated antenna. Do you now any with long range?
juanmol:
Not a lot of information to go on there.
Please describe your project and what it is you are actually trying to do.
Give details of the equipment you are using or planning to use.
You need to be fairly specific on what range you want, 'long range' is meaningless on its own.
I have had a pair of nRF24L01+ modules with PCB antennas communicating at 110 metres range outdoors with clear line of sight. That probably was not the limit, but I could not see the other device if I moved further away (poorly designed experiment).
PCB antennas tend to be short and only suited to high frequency devices. Lower frequency wireless has a longer range.
...R
