Radio Controlled Car?
I have a Futaba 2-channel RC transmitter set for RF 75.630 MHz. How do I interface it with the Arduino Uno? I saw a tutorial on Sparkfun website at RC Hobby Controllers and Arduino - SparkFun Electronics but which RC receiver should I buy?
You need to figure out if your transmitter is AM or FM, then any AM or FM (match the transmitter) 75Mhz 2 channel receiver will do. Some countries have restrictions on what a 75Mhz radio can be used for, check in your country.
Also that tutorial is a bit questionable, try this instead -
Duane B
The tutorials at RCArduino don't tell me if I need a RC receiver. I also tried to set up IR communcation but I don't know which code for which button on the remote control. The Serial Monitor displays a few codes when I press a button.
This looks like it's your first attempt to do something with an RC anything, so what ever your planing to do you need to start with a working car with a RX'er which is controlled from a working TX'er.
Get hold of a cheap "toy" as cheap as you can find. I paid 6.50 pounds for the one I'm working on.
Put the futaba away its an expensive brand.
I have Tamiya 1:10 scale Twin Detonator with Tamiya ESC and Futaba radio system and a 1:8 scale (I think) New Volkswagen Beetle made by New Bright. I had problems controlling the ESC from Arduino because the ESC has braking feature that requires me to release the throttle stick on the transmitter before running the truck in reverse. I need an ESC that doesn't have braking feature. The VW has a weird steering motor with encoder. I modified the chassis for a steering servo but the horn interfers with the tie rod. I have a R2D2 robot that requires me to talk to it to get it to move and I want to modify it for RC.
@ jeffmorris
I think you really should start a thread of your own and which of your systems, projects and/or problems do you want to talk about
Mark
Forget about IR and RF communications. I will try Bluetooth communication.
jeffmorris:
You do realize using common BT designs that will work only if you keep the car within a couple feet from the transmitter, right? You could probably significantly multiple range with a highly directional transmitter antenna, but from my understanding the antennas normally used in BT devices are more or less omnidirectional.
I thought that setting up Bluetooth communication is easier than IR or RF communication. I found out that I can use my Samsung Galaxy 7.0 Plus tablet to control robots thru Bluetooth. I ordered the items that I need for Bluetooth communication from Sparkfun.
jeffmorris:
It probably will be easier. However, my reply was about the range you could expect. Most BT modules in phones and tablets are lowe power and will have a much small reliable range than IR or AM/FM based control system. I'm not implying it can't be done. I'm just letting you know that you shouldn't expect to be able to control the car from the more than a few feet away.
I've used a 2.4Ghz XBee link and gotten control to nearly 1km!
Now I have some "free" time I'm going to use the 900Mhz XBee Pro modules I have
Give me a yell if you want my Version 1 code, it's easy and simple.
