Radio Controlled Scale that activates and LED
Hello friends....
I'm working on a project and am stuck right at the end. The idea behind the project is that of having a load cell attached to an Adafruit Feather M0 RFM69HCW Packet Radio sending a packet to another Adafruit Feather M0 RFM69HCW Packet Radio attached to an led. When a weight between 5g-8g grams is placed on the scale the LED will flash. When a weight that is between 13g and 15g is placed on the scale the LED will stay solid.
My code seems to be working with the initial 5g - 8g but doesn't work with the heavier weight. I'm stuck and would love some help
Here is My sending unit code
#include <SPI.h>
#include <RH_RF69.h>
#include <HX711_ADC.h>
#include <Wire.h>
HX711_ADC scale (11,12); // 6 is green 7 is orange
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 915.0
#if defined(ADAFRUIT_FEATHER_M0) || defined(ADAFRUIT_FEATHER_M0_EXPRESS) || defined(ARDUINO_SAMD_FEATHER_M0)  // Feather M0 w/Radio
  #define RFM69_CS    8
  #define RFM69_INT   3
  #define RFM69_RST   4
  #define LED        13
#endif
// Singleton instance of the radio driver
RH_RF69 rf69(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  scale.begin();
    scale.start(2000);
    scale.setCalFactor(1000.0);
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
 Serial.println("Feather RFM69 TX Test!");
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
   if (!rf69.init()) {
    Serial.println("RFM69 radio init failed");
    while (1);
   Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
    Serial.println("setFrequency failed");
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
    Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
  scale.update(); // retrieves data from the load cell
  float i = scale.getData(); // get output value
Serial.print(scale.getData(), 1);
Serial.println("measurement");
delay(200);
 if (i >= 5 && i <= 8) { // Blue is Blinking
char radiopacket[20] = "BLUE";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
   // Send a message!
  rf69.send((uint8_t *)radiopacket, strlen(radiopacket));
  rf69.waitPacketSent();
   if (i >= 13 && i <= 15) { //Red is solid
char radiopacket[20] = "RED";
   // Send a message!
  // Now wait for a reply
  uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  if (rf69.waitAvailableTimeout(500)) {
    // Should be a reply message for us now
    if (rf69.recv(buf, &len)) {
      Serial.print("Got a reply: ");
      Serial.println((char*)buf);
      Serial.println("Receive failed");
    Serial.println("No reply, is another RFM69 listening?");
Here is my receiving code
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing
// or reliability, so you should only use RH_RF69 if you do not need the
// higher level messaging abilities.
// It is designed to work with the other example RadioHead69_RawDemo_TX.
// Demonstrates the use of AES encryption, setting the frequency and
// modem configuration.
#include <SPI.h>
  #define RFM69_CS    8
  #define RFM69_INT   3
  #define RFM69_RST   4
  #define LED        13
  #define LEDPIN 11
#endif
/* Teensy 3.x w/wing
#define RFM69_CS     10  // "B"
#define RFM69_INT     4  // "C"
#define RFM69_RST     9  // "A"
#define RFM69_IRQN   digitalPinToInterrupt(RFM69_INT)
/* WICED Feather w/wing
#define RFM69_CS     PB4  // "B"
#define RFM69_INT    PA15 // "C"
#define RFM69_RST    PA4  // "A"
#define RFM69_IRQN   RFM69_INT
  //while (!Serial) delay(1); // Wait for Serial Console (comment out line if no computer)
  pinMode(LEDPIN, OUTPUT);
  Serial.println("Feather RFM69 RX Test!");
  // manual reset
  delay(10);
  delay(10);
  if (!rf69.init()) {
    while (1);
  // No encryption
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
 if (rf69.available()) {
    // Should be a message for us now
      if (!len) return;
      buf[len] = 0;
      Serial.print("Received [");
      Serial.print(len);
      Serial.print("]: ");
      Serial.print("RSSI: ");
      Serial.println(rf69.lastRssi(), DEC);
   if (strstr((char *)buf, "BLUE")) {
        // Send a reply!
        uint8_t data[] = "Blue back to you";
        rf69.send(data, sizeof(data));
        Serial.println("Sent a reply");
        digitalWrite (LEDPIN, HIGH);
delay (1000);
digitalWrite (LEDPIN, LOW);
  if (strstr((char *)buf, "RED")) {
        // Send a reply!
        uint8_t data[] = "Red Back To You";
void Blink(byte pin, byte delay_ms, byte loops) {
  while (loops--) {
    digitalWrite(pin, HIGH);
    delay(delay_ms);
    digitalWrite(pin, LOW);
    delay(delay_ms);
What happens instead?
Put Serial.print() statements at appropriate places in both the TX and RX code, to see if variables are what you expect them to be.
