Radio example won´t compile
Hello,
i am using 1.8.2 and installed the radio library with the function of the programm itself. The lib is this one: http://www.mathertel.de/Arduino/RadioLibrary.aspx I open SerialRadio from the examples and try to compile it, but i get lot of different errors:
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\USER\AppData\Local\Temp\arduino_build_726231\libraries\Radio\RDA5807M.cpp.o (symbol from plugin): In function `RDA5807M::RDA5807M()':
(.text+0x0): multiple definition of `RDA5807M::RDA5807M()'
C:\Users\USER\AppData\Local\Temp\arduino_build_726231\sketch\RDA5807M.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `RDA5807M::_write16(unsigned int)'
(.text+0x0): multiple definition of `RDA5807M::_saveRegisters()'
(.text+0x0): multiple definition of `RDA5807M::term()'
(.text+0x0): multiple definition of `RDA5807M::setBand(RADIO_BAND)'
(.text+0x0): multiple definition of `RDA5807M::_saveRegister(unsigned char)'
C:\Users\USER\AppData\Local\Temp\arduino_build_726231\sketch\RDA5807M.cpp:215:12: note: 'r' was declared here
   uint16_t r;
collect2.exe: error: ld returned 1 exit status
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library Radio at version 1.0.0 in folder: C:\Users\USER\Documents\Arduino\libraries\Radio
exit status 1
Error compiling for board Arduino/Genuino Uno.
What is wrong?
The problem is likely to be in the code that was not posted.
Try restarting the Arduino IDE. Let us know if that fixes the problem.
The problem gets fixed, when you download the lib(s) and example(s) directly from the authors website: http://www.mathertel.de/Arduino/RadioLibrary.aspx
The ones that get automatically download by the arduino ide is broken.
