if write a code to make 21000000(MHZ) cylcles per second and connect a antenna wire in any digital out pin.doesn't it produce radio waves.I know i am basically have bad basic knowledge. Please help me to understand what is my misunderstanding.
actually if i want to send a data 1001(9) with carrier frequency of 21MHZ(t=21um)
why dont i make mark of 20 ms(1) 10ms(0) 10ms(0) and finally 20ms(1) with space of 10ms
if i do same decoding on other side wont i get the vale
A logic signal isn't sinusoidal so you'd output a whole bunch of harmonics across the
spectrum too... This is the cause of electro-magnetic interference from digital electronics
and why you specifically avoid hanging single wires off a signal.
ohhh. So ,is it the reason why Xbee and rf modules are.isn't it?
Those modules convert digital into analog signals and transmit with some modulation tecqnuice which is same as used in receiver side and it will be again decode to digital data. The transmission is in analog so no harmonics i mean noise ,am i right?
Yes. They use the correct frequencies and are type approved. That means the design has been submitted to testing by an approved test house.
They also know what they are doing.
No you are not right. All RF transmitters produce harmonics the trick is to keep them to an absolute minimum. Turning a transmitter on and off produces harmonics all over the band.
the licence free band vary for different countries.so the xbee and rf have different working frequencies in different country
okay.By the way i have tried ir transmission with pwm modulation to control my sony bravio tv.Then i started to think why don't we use same way to produce rf transmission.That leads me here
I don't know and can't imagine how you arrive at a tiny fraction of a millimetre as an antenna length for a 38kHz radio wave.
Put it this way, in air, a 40kHz ultrasound signal has a wavelength of over eight millimetres.
Sound travels an awful lot slower than radio.
bhuvaneshnick:
this is the calculation as far as i know, thats why the AM towers are taller that FM
As far as I'm aware, the modulation scheme has little to do with antenna length.
Frequency is an entirely different matter, however.
So what is that supposed to prove.
That is not the calculation you were making. You were trying to work out the wavelength of a 38KHz radio wave. Put that number in and you get the same result as the Wikipedia page.
So?
Who ever heard of a useful or sensible Instructable?
What it shows is that for a Bluetooth antenna, you need a shortish antenna.
For a 2.4GHz signal.
Well, keine Scheiss Einstein.
