I am trying to create a digitally controlled garden. My first step in this project is to create a Radiometer to measure the available light in the garden. I am planning on taking hourly readings from at least one sensor and push that to a database to monitor changes over the season.
I want the sensor to be accurate; I have been researching different types of light meters. I have read that to be accurate I should use a solar cell not a photo-resister and measure the current from the solar cell not the voltage.
If I hook up the solar cell to a small fan, what is the easiest way to measure the current in that circuit as something I can read on an Arduino pin?
You can “meassure” 2 things with Arduino, either digital 0 (=0V) or 1 (=5V) on the digital pins, or 0 - 5V on the analog pins, Arduino vil convert this voltage to a number in the range 0 - 1023.
So your best bet is to find a way to convert current to voltage. some info here
Just to add back to the group, I think this is the site JaguarJoe used. I think accuratly measuring solar radiation is going to be difficult, but I am not giving up yet.
