Hello everyone, I'm new to the arduino world and have started working on some LED projects. Ultimately what I would like to do is use a series of LED strips to create Christmas lights for next Christmas. They'll blink, fade, move and change colors... all that.
I've gone through several tutorials using LEDs and every project has used the PWM pins, however the TriColor uses A0 as an output. I'm able to get it to work using the sketch that came with the setup. I have a couple of questions.
How do I get the strip to fade (pulse)
and how can I get the strip to work using the PWM pins instead of the analogInput pins?
library and pin designation
#include <avr/pgmspace.h>
// ******** DEBUG ==== should auto config to adapt different mother board *********
//#define DATA_1 (PORTF |= 0X01) // DATA 1 // for ATMEGA
//#define DATA_0 (PORTF &= 0XFE) // DATA 0 // for ATMEGA
//#define STRIP_PINOUT DDRF=0xFF // for ATMEGA
#define DATA_1 (PORTC |= 0X01) // DATA 1 // for UNO
#define DATA_0 (PORTC &= 0XFE) // DATA 0 // for UNO
#define STRIP_PINOUT (DDRC=0xFF) // for UNO
LED display
PROGMEM const unsigned long pattern_test_red[10][10]={
{0xff0000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0xff0000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0xff0000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0xff0000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0xff0000,0x000000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0x000000,0xff0000,0x000000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xff0000,0x000000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xff0000,0x000000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xff0000,0x000000},
{0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0x000000,0xff0000},
