FQBN: arduino:megaavr:nona4809:mode=off
Utilizzo della scheda 'nona4809' dalla piattaforma nella cartella: C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Utilizzo del core 'arduino' dalla piattaforma nella cartella: C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8
Rilevamento delle librerie utilizzate in corso...
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp" -o nul
Alternative per Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidati: [Wire@1.0]
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp" -o nul
Alternative per Adafruit_PWMServoDriver.h: [Adafruit PWM Servo Driver Library@2.4.1]
ResolveLibrary(Adafruit_PWMServoDriver.h)
-> candidati: [Adafruit PWM Servo Driver Library@2.4.1]
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\antos\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_PWM_Servo_Driver_Library" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp" -o nul
Utilizzo delle dipendenze delle librerie nella cache per i file: C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\Wire.cpp
Utilizzo delle dipendenze delle librerie nella cache per i file: C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src\utility\twi.c
Utilizzo delle dipendenze delle librerie nella cache per i file: c:\Users\antos\OneDrive\Documenti\Arduino\libraries\Adafruit_PWM_Servo_Driver_Library\Adafruit_PWMServoDriver.cpp
Sto generando i prototipi di funzione...
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\antos\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_PWM_Servo_Driver_Library" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp" -o "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilazione sketch...
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\antos\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_PWM_Servo_Driver_Library" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp" -o "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp.o"
Compilazione librerie...
Compilazione libreria "Wire"
Uso il file precedentemente compilato: C:\Users\antos\AppData\Local\Temp\arduino\sketches\1C38B1801072DB65E547E3595C299EB5\libraries\Wire\utility\twi.c.o
Uso il file precedentemente compilato: C:\Users\antos\AppData\Local\Temp\arduino\sketches\1C38B1801072DB65E547E3595C299EB5\libraries\Wire\Wire.cpp.o
Compilazione libreria "Adafruit PWM Servo Driver Library"
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino/api/deprecated" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\cores\\arduino" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\variants\\nona4809" "-IC:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.8\\libraries\\Wire\\src" "-Ic:\\Users\\antos\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_PWM_Servo_Driver_Library" "c:\\Users\\antos\\OneDrive\\Documenti\\Arduino\\libraries\\Adafruit_PWM_Servo_Driver_Library\\Adafruit_PWMServoDriver.cpp" -o "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\libraries\\Adafruit_PWM_Servo_Driver_Library\\Adafruit_PWMServoDriver.cpp.o"
In file included from c:\Users\antos\OneDrive\Documenti\Arduino\libraries\Adafruit_PWM_Servo_Driver_Library\Adafruit_PWMServoDriver.h:27:0,
from c:\Users\antos\OneDrive\Documenti\Arduino\libraries\Adafruit_PWM_Servo_Driver_Library\Adafruit_PWMServoDriver.cpp:30:
C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function 'uint8_t Adafruit_PWMServoDriver::read8(uint8_t)':
C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:63:12: note: candidate 1: size_t TwoWire::requestFrom(int, int)
size_t requestFrom(int, int);
C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:61:12: note: candidate 2: virtual size_t TwoWire::requestFrom(uint8_t, size_t)
size_t requestFrom(uint8_t, size_t);
Compilazione core...
Uso il file precedentemente compilato: C:\Users\antos\AppData\Local\Temp\arduino\sketches\1C38B1801072DB65E547E3595C299EB5\core\variant.c.o
Utilizzo del core precompilato: C:\Users\antos\AppData\Local\Temp\arduino\cores\arduino_megaavr_nona4809_mode_off_d12d24015d401e539381f85ae98dc5e0\core.a
Collegare tutto insieme...
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mmcu=atmega4809 -o "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.elf" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\sketch\\mk5_sketch_11-28-2021.ino.cpp.o" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\libraries\\Adafruit_PWM_Servo_Driver_Library\\Adafruit_PWMServoDriver.cpp.o" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5\\core\\variant.c.o" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/..\\..\\cores\\arduino_megaavr_nona4809_mode_off_d12d24015d401e539381f85ae98dc5e0\\core.a" "-LC:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5" -lm "-Wl,-Map,C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.map"
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O binary -R .eeprom "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.elf" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.bin"
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.elf" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.eep"
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.elf" "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.hex"
Uso la libreria Wire alla versione 1.0 nella cartella: C:\Users\antos\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire
Uso la libreria Adafruit PWM Servo Driver Library alla versione 2.4.1 nella cartella: C:\Users\antos\OneDrive\Documenti\Arduino\libraries\Adafruit_PWM_Servo_Driver_Library
"C:\\Users\\antos\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-size" -A "C:\\Users\\antos\\AppData\\Local\\Temp\\arduino\\sketches\\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.elf"
Lo sketch usa 8317 byte (16%) dello spazio disponibile per i programmi. Il massimo è 49152 byte.
Le variabili globali usano 493 byte (8%) di memoria dinamica, lasciando altri 5651 byte liberi per le variabili locali. Il massimo è 6144 byte.
Esecuzione di un touch reset a 1200-bps sulla porta seriale COM4
"C:\Users\antos\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\antos\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega4809 -cjtag2updi -PCOM4 -b115200 -e -D "-Uflash:w:C:\Users\antos\AppData\Local\Temp\arduino\sketches\1C38B1801072DB65E547E3595C299EB5/mk5_sketch_11-28-2021.ino.hex:i" "-Ufuse2:w:0x01:m" "-Ufuse5:w:0xC9:m" "-Ufuse8:w:0x00:m" {upload.extra_files}
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\antos\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 6.00
hardware version: 1
S_MCU:
hardware version: 1
Serial number: 0a:0b:0c:0d:0e:0f
Device ID: Thinary mkII
AVR Part : ATmega4809
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
prodsig 0 0 0 0 no 61 61 0 0 0 0x00 0x00
fuses 0 0 0 0 no 9 0 0 0 0 0x00 0x00
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse6 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse7 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse8 0 0 0 0 no 1 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00
data 0 0 0 0 no 0 0 0 0 0 0x00 0x00
usersig 0 0 0 0 no 64 64 0 0 0 0x00 0x00
flash 0 0 0 0 no 49152 128 0 0 0 0x00 0x00
eeprom 0 0 0 0 no 256 64 0 0 0 0x00 0x00
Programmer Type : JTAGMKII_PDI
Description : JTAGv2 to UPDI bridge
M_MCU hardware version: 1
M_MCU firmware version: 6.00
S_MCU hardware version: 1
S_MCU firmware version: 6.00
Vtarget : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.28s
avrdude: Device signature = 0x1e9650 (probably m4808)
avrdude: Expected signature for ATmega4809 is 1E 96 51
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Caricamento non riuscito: errore durante il caricamento: exit status 1
Buonasera e benvenuto nella sezione Italiana del forum,
prima di tutto ti segnalo che, nella sezione in lingua Inglese, si può scrivere SOLO in Inglese ... quindi, per favore, la prossima volta presta più attenzione in quale sezione metti i tuoi post; questa volta esso è stato spostato, da un moderatore della sezione di lingua Inglese, nella sezione di lingua Italiana ... la prossima volta potrebbe venire direttamente eliminato, dopo di che ...
... cortesemente, leggi attentamente il REGOLAMENTO di detta sezione, (... e, per evitare future possibili discussioni/incomprensioni, prestando molta attenzione al punto 15) e poi, come da suddetto regolamento (punto 16.7), fai la tua presentazione NELL'APPOSITA DISCUSSIONE spiegando bene quali esperienze hai in elettronica e programmazione, affinché noi possiamo conoscere la tua esperienza ed esprimerci con termini adeguati.
Grazie,
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposita discussione, nel rispetto del succitato regolamento nessuno ti risponderà (eventuali risposte o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farla al più presto.
P.P.S.: Evitate di utilizzare la traduzione automatica fatta dal browser ... vi impedisce di capire la lingua della sezione dove andate a scrivere ...
