Railwaycrossing
Hi guys, I need to make an automatic railway crossing for school. I wrote a program but for some reason it isn’t working.There are 2 light sensors 1 in front of the crossing and 1 behind the crossing so when the train rides over the first one it opens and when it rides over the 2nd one it closes.
here is the code:
#include <Servo.h>
Servo myServo;
int LDR = 0; //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDR2 = 1;
int LDRValue = 0; //that¹s a variable to store LDR values
int LDRValue2 = 0;
int light_sensitivity = 90; //This is the approx value of lightsurrounding your LDR
Serial.begin(9600); //start the serial monitor with 9600 buad
pinMode(13, OUTPUT); //we mostly use 13 because there is already abuilt in yellow LED in arduino which shows output when 13 pin is enabled
myServo.attach(9);
LDRValue = analogRead(LDR); //reads the ldr¹s value through LDR
LDRValue2 = analogRead(LDR); //reads the second ldr¹s value throughLDR
Serial.println(LDRValue);//prints the LDR values to serialmonitor
Serial.println(LDRValue2);
delay(50); //This is the speed by which LDR sends value to arduino
if (LDRValue < light_sensitivity || LDRValue2 < light_sensitivity)
myServo.write(180);
digitalWrite(13, HIGH);
myServo.write(90);
digitalWrite(13, LOW);
You never read LDR2.
This code is not as you intend, I think. The second value should be LDR2?
Have a look here
When posting code, we ask you to please use code tags to ensure there’s no ambiguity.
