Rainbowduino I2C Singledot
Dear Community,
i think it is a little bit hard to understand the function of the rainbowduino.
But Seedstudio says that rainbowduino sells like hot cake.
So there must be a lot of people which make use of rainbowduino.
I searched nearly the whole internet for informationgathering, but
it looks a little bit less.
In the Documentation there are some (5 Commands) as Host Sample API.
Is somebody here who has expanded the abilities of Rainbowduino I2C ?
What I want to do ist something like "SetPixel (x,y,r,g,b);".
I thought asking is the first step... i will do my best to get it work, but if you already have such a function... then please post it here....
Thank you!
ChrisS
Dear Community,
i've found an example for controlling RGB Strips instead of Led-Matrix.
Looks simple.
#include "Rainbow.h"
unsigned char NumTab[10]=
  0x77,0x06,0x5b,0x1f,0x2e,0x3d,0x7d,0x17,0x7f,0x3f
  _init();
  close_all_line
  open_all_line
  int i;
  for(i=0;i<10;i++)
    shift_24_bit(NumTab[i],0,0);
void _init(void)    // define the pin mode
  DDRD=0xff;
  DDRC=0xff;
  DDRB=0xff;
  PORTD=0;
  PORTB=0;
void shift_1_bit(unsigned char LS)
  if(LS) shift_data_1;
  else  shift_data_0;
  clk_rising;
void shift_24_bit(int Red,int Green,int Blue)
  unsigned char i;
  le_high;
  for (i=0;i<8;i++)
    if ((Green<<i)&0x80)   shift_1_bit(1);
    else                 shift_1_bit(0);
  for (i=0;i<8;i++)
    if ((Red<<i)&0x80) shift_1_bit(1);
  for (i=0;i<8;i++)
    if ((Blue<<i)&0x80)  shift_1_bit(1);
  le_low;
The sketch controls 7 Strips like a 7-Segment Display.
Digits 0 - 9 where displayed.
On Top of the Sketch there is an array of 10 hex codes... i think that are the codes of displaying the digits.
But I don't understand that Hex-Values.
Would it be please possible to explain me what happening there.
Thank you und Greetings
ChrisS
