I get this error and cannot compile the code I downloaded from Github.
no matching function for call to 'ParticleSys::ParticleSys(const byte&, Particle_Fixed [70], Emitter_Fountain*)'
Can anyone point me to a fix?
Thanks in advance.
Please post the full sketch, using code tags when you do, and a link to where you downloaded it from
Sorry but I don't know what CODE TAGS are.
- Copyright (C) 2013 Gilad Dayagi. All rights reserved.
- This program is free software: you can redistribute it and/or modify
- it under the terms of the GNU Lesser General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- An example for the Arduino particle system library
- Creates a spinning galaxy effect
//'r' for rainbowduino, 'c' for colorduino
#define BOARD 'r'
#if BOARD == 'c'
#include <Colorduino.h>
#else
#include <Rainbowduino.h>
#endif
#include "ParticleSys.h"
#include "Particle_Bounce.h"
#include "Emitter_Spin.h"
#include "PartMatrix.h"
const byte numParticles = 60;
Particle_Bounce particles[numParticles];
Emitter_Spin emitter(112, 112, 5, 7);
ParticleSys pSys(numParticles, particles, &emitter); // this is where the error pops up
PartMatrix pMatrix;
- Render the particles into a low-resolution matrix
void drawMatrix(){
pMatrix.fade();
pMatrix.render(particles, numParticles);
//update the actual LED matrix
for (byte y=0;y<PS_PIXELS_Y;y++) {
for(byte x=0;x<PS_PIXELS_X;x++) {
#if BOARD == 'c'
Colorduino.SetPixel(x, y, pMatrix.matrix[x][y].r, pMatrix.matrix[x][y].g, pMatrix.matrix[x][y].b);
#else
Rb.setPixelXY(x, y, pMatrix.matrix[x][y].r, pMatrix.matrix[x][y].g, pMatrix.matrix[x][y].b);
#endif
#if BOARD == 'c'
Colorduino.Init(); // initialize the board
// compensate for relative intensity differences in R/G/B brightness
// array of 6-bit base values for RGB (0~63)
// whiteBalVal[0]=red
// whiteBalVal[1]=green
// whiteBalVal[2]=blue
byte whiteBalVal[3] = {36,63,7}; // for LEDSEE 6x6cm round matrix
Colorduino.SetWhiteBal(whiteBalVal);
#else
Rb.init();
#endif
randomSeed(analogRead(0));
pMatrix.reset();
PartMatrix::isOverflow = true;
emitter.oscilate = true;
pSys.update();
drawMatrix();
#if BOARD == 'c'
Colorduino.FlipPage();
#endif
delay(30);
Retrevied from this site:
https://raw.githubusercontent.com/giladaya/arduino-particle-sys/master/examples/Spin/Spin.ino
Check marks are: [x]Preformatted text
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Okay I think I understand now.
type or paste code here:
* Copyright (C) 2013 Gilad Dayagi. All rights reserved.
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* An example for the Arduino particle system library
* Creates a spinning galaxy effect
#define BOARD 'r'
#if BOARD == 'c'
#else
#endif
ParticleSys pSys(numParticles, particles, &emitter); // error is here
PartMatrix pMatrix;
* Render the particles into a low-resolution matrix
void drawMatrix(){
pMatrix.fade();
#if BOARD == 'c'
#else
#endif
#if BOARD == 'c'
#else
Rb.init();
#endif
pMatrix.reset();
pSys.update();
drawMatrix();
#if BOARD == 'c'
#endif
delay(30);
Yes it worked. Now I understand. Thanks
